Transmission Clunk/ Rear End Sound 2023 DCLB
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Buildup21, Mar 28, 2023.
  1. Mar 28, 2023 at 6:12 PM
    Buildup21
    Buildup21 [OP] Member
    Am I getting the run around?
    I just bought a 2023 Tacoma DCLB about a month or so ago. I have noticed when I start the truck and go from park to drive, the truck makes a loud clanking/locking sound from the rear end, and the whole truck shakes from right to left. Is this normal for these trucks? I called the dealership and talked to a technician and he said every Tacoma on the lot would do this excact same thing. I like to trust people/experts, but I saved for a long time and am really young so this was a huge purchase for me. If this is not normal I would like it to be taken care of before the issue escalates. Thanks in advance!
  2. Mar 28, 2023 at 6:23 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Have a trusted friend outside the truck when you make it sound off and try to pinpoint the location.
    Take the dealer tech, not the service writer, for a test drive.
    BlackTRD4Me likes this.
  3. Mar 28, 2023 at 6:28 PM
    Buildup21
    It was the dealer tech I spoke to, and he said it was normal and that every Tacoma does it because “it’s meant for offroad”
    HondaGM likes this.
  4. Mar 28, 2023 at 6:30 PM
    eurowner
    eurowner Duke Sky
    Scoty
    . Fkn bullshit.
    My TRDOR DCLB does not make any of those noises.
    HondaGM likes this.
  5. Mar 28, 2023 at 6:38 PM
    Buildup21
    It’s very hard to describe the sound. But basically if I start the truck, let it idle down, shift slowly and individually between Park-Reverse-Neutral- Drive letting the rpm’s drop each time….. once I switch into drive there is a loud locking/clunking/smacking sound that makes the whole truck wobble to the right.
  6. Mar 28, 2023 at 6:41 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Yep my 22 doesn’t make any noise either. If you shift to reverse or drive in a cold start while the initial start program is running and the rpm’s are yonit will make a jump but that’s due to higher revs on startups.
    Dfpftw likes this.
  7. Mar 28, 2023 at 6:43 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    It doesn't sound like what your issue is but just to put it out there if you shift between drive and reverse multiple times repeatedly then the truck will assume youre stuck and boost line pressure expecting you to pound on it to try and get it unstuck thus making harsh gear engagement. Again, I don't think that is what you're explaining.
  8. Mar 28, 2023 at 6:44 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Is it axle wrap? Mine does this, annoying, but normal.
  9. Mar 28, 2023 at 6:44 PM
    Buildup21
    Correct, it does it when just going from to park to drive. But I appreciate any new knowledge. Thank you
    AJKlug1[QUOTED] likes this.
  10. Mar 28, 2023 at 6:47 PM
    eurowner
    eurowner Duke Sky
    Scoty
    /\ and then take it to a new dealer.
  11. Mar 28, 2023 at 6:52 PM
    Buildup21
    What sucks is I called two dealers. The one I bought it from, which is the one I spoke with a tec at… and a closer one that wanted to charge me to look at it
  12. Mar 28, 2023 at 6:53 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Mmmmm…..I call BS
  13. Mar 28, 2023 at 6:54 PM
    eurowner
    eurowner Duke Sky
    Scoty
    You haven’t brought the truck to a dealer?
  14. Mar 28, 2023 at 6:55 PM
    Buildup21
    The close one wanted to charge me money, the one I bought it from is far, and said it was completely normal.
    HondaGM likes this.
  15. Mar 28, 2023 at 6:56 PM
    eurowner
    eurowner Duke Sky
    Scoty
  16. Mar 28, 2023 at 6:56 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    This is a brand new truck?
  17. Mar 28, 2023 at 6:58 PM
    Buildup21
    Yes, I bought it brand new. Only has 1100 miles on it currently
    HondaGM[QUOTED] likes this.
  18. Mar 28, 2023 at 6:58 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I don’t know about these other folks not having any noises, but I can definitely say every RWD vehicle I’ve ever owned has had significant driveline slop and it’s heard/felt exactly like this. On manuals it’s felt when you give it gas either off of coasting, changing direction, or coasting in neutral. On autos, it happens shifting between D and R because the driveshaft starts going the opposite direction and spins the diff to the limit.
  19. Mar 28, 2023 at 7:01 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Ok…so it’s supposed to clunk cause it’s an off-road vehicle…and if you have a problem with it you have to pay to get it looked at…on a brand new truck…can you get a video of the noise?
  20. Mar 28, 2023 at 7:03 PM
    Buildup21
    That’s basically what happened to me today, yes. I’m a college student who worked extremely hard to buy this truck. Wanted one for years. Honestly been a pretty disappointing day
