transmission cooler for 4cyl taco
Discussion in 'Towing' started by themeat424, Oct 17, 2012.
  1. Oct 17, 2012 at 10:21 PM
    themeat424
    themeat424 [OP] Active Member
    NY
    12 Regular Cab 4x4 Auto
    I posted this in the 4 cyl section, but I think I might have a better chance getting an answer here. Can someone tell me if there is a difference between the aftermarket transmission coolers for the V6 5 speed tacos vs the 4 cyl 4 speed tacos? Basically, do I need a cooler of a different size being that the transmission has one less gear and I'm guessing holds less fluid? Or are they essentially the same and the hayden 678 that others have installed in their V6 trucks a good fit for the 4 speed trucks too? Thanks!
  2. Nov 25, 2012 at 4:45 AM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
