Transmission Cooler question.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chadrick, Nov 2, 2012.
  1. Nov 2, 2012 at 10:20 PM
    Chadrick
    Chadrick [OP] Member
    Chad
    Upstae NY (real upstate) :)
    09 Off Road, SR5, TRD, White
    Hi guys. Been reading a lot and I am led to believe that my 09 TRD Off Road has a transmission cooler. Can any of you experts tell me for sure.
    Thank you.
  2. Nov 2, 2012 at 10:26 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Factory hitch, 7-pin connector, trailer braking wiring, and oil cooler under the filter?
    If so, you have the towing package and a trans cooler.
  3. Nov 2, 2012 at 10:35 PM
    Chadrick
    Chad
    It has the 7 pin connector. The hitch is factory. It is installed under the bumper. Not on top of the bumper. As for the oil cooler under the filter. I have no idea. Again sounds like I must have one. The reason I ask is I am towing a 3000pd travel trailer and just worry that it will not kill my tranny. I tow it probably 10 times a season. I think I should be okay but like to get TW members to give me a piece of mind.
    Thanks Rich. Really appreciated.
  4. Nov 2, 2012 at 10:37 PM
    Chadrick
    Chad
    Sorry. Also has the trailer brake wiring.
  5. Nov 2, 2012 at 10:50 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Factory hitch is going to have the trans cooler (if you have an auto trans).
    The oil cooler (assuming you have a V6) is that "donut" like thing under the oil filter with two hoses coming from it.
    It simply circulates coolant through the oil filter mounting base.
  6. Nov 2, 2012 at 11:15 PM
    Chadrick
    Chad
    Sweet. Just went and checked it out. I see the donut shaped thing under the oil filter. I am happy you have confirmed with me that my Tacoma is equipped with a trans cooler.
    Thanks for your time Rich.
