Transmission crossmember bolts and nuts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by akoaypogi29, Jun 3, 2024.
  1. Jun 3, 2024 at 11:36 AM
    akoaypogi29
    akoaypogi29 [OP] Active Member
    Raymond
    2019 MGM TRD Off Road
    Front bumper
    Does anyone know the part number of the transmission crossmember bolts for 2019 Tacoma trd off-road I do believe the bolt probably 5" long and the nut is 14mm I just can't find any help will appreciate it.
  2. Jun 3, 2024 at 11:39 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I do not know for sure, but you can certainly remove a nut while parked with no issues. Take that into Ace, H-D, etc. and get the thread. A 14mm nut would have me guessing M10 x 1.0?
    HondaGM and gudujarlson like this.
  3. Jun 3, 2024 at 5:28 PM
    CPS-65
    CPS-65 I’m good for some, but I’m not for everyone.
    Alta Loma, CA
    2019 Quicksand TRD Off Road 4X4
    Mostly old man mods
    Make sure any hardware you replace from a store is a class 10.9. Automotive bolts can also be odd lengths, so make sure whatever you choose, it clamps correctly.
  4. Jun 3, 2024 at 6:39 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Nuts and bolts are commodities available from many sources. There’s not much reason to buy them from a OEM source. It’s not like Toyota manufactures them. Just make sure to use the same or better quality grade. I’m not even sure Toyota lists part numbers for generic bolts and nuts. They are more likely part of a larger part assembly.
    HondaGM likes this.
  5. Jun 4, 2024 at 3:27 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Dealer can help you
    HondaGM likes this.
  6. Jun 4, 2024 at 7:56 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    HondaGM likes this.
  7. Jun 4, 2024 at 10:35 AM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    HondaGM likes this.
  8. Jun 4, 2024 at 10:48 AM
    Vlady
    Issy, WA
    Probably.
    The bracket looks identical on 2nd gen and 3rd gen drawings. Actual part number could be revised.
    Better than go to HD
  9. Jun 4, 2024 at 10:50 AM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Cool……thanks
