Transmission dilemma.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MarlonB54, Jan 16, 2025.
  1. Jan 16, 2025 at 2:13 PM
    MarlonB54
    MarlonB54 [OP] Well-Known Member
    Fishaholic
    22’ Barcelona Red TRD Off Road
    I had a front end accident last year in November. Collision center completed repairs and got truck back just fine. My brother who used to be a mechanic inspected the repairs and noticed a hose that was sitting there connected to another hose. Turned out to be the transmission line that runs to the radiator. I drove the truck mainly on highway 60-80mph in the cold weather for roughly 2 weeks. The transmission temp light never came up. I raised hell back at the collision center and they did a fluid inspection flush and refill. I was going through a lot of stuff at the time and decided to trust and just keep driving. Its been a year, 15,000 miles later nothing crazy has happened. I do suspect sometimes the truck randomly slips not often. I almost feel like it used to happen before the accident. I run the CVC tune. How screwed am I? I do have it in writing that they messed up and just tell me to take it back to them if anything is wrong. Its been a year and some months and I drive a lot. How much damage couldve occured? I didnt tow or off road just commuted to work 30 miles round trip daily on the highway
  2. Jan 16, 2025 at 2:30 PM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    So the collision shop put the wrong radiator in and then didn’t put the correct one in after you identified the problem over a year ago? I would contact your insurance company and tell them what happened. Most likely the estimator picked the wrong radiator and instead of the collision repair facility writing a supplement to get the correct radiator, they just doubled the trans cooler lines back on themself. Not a horrible situation but I would definitely try to get it returned to the pre-collision state.
  3. Jan 16, 2025 at 2:34 PM
    MarlonB54
    Fishaholic
    I wrote this all messed up, sorry. During repairs, they bypassed the transmission line to radiator to minimize coolant loss and never connected the transmission line back to the radiator when they turned the truck over. I went back to them and showed them then thats when they hooked it up and flushed the transmission fluid. Isnt driving with them doubled on themselves bad since the transmission wasnt getting cooled by the radiator??
  4. Jan 16, 2025 at 2:51 PM
    airforceb2cc
    Don
    KCMO
    I wouldn’t worry too much about that at all then. Long steep grades or towing in the dead of summer would be one thing but a couple weeks in the winter for small daily commutes, I wouldn’t bat an eye at it.
    Phlogiston likes this.
  5. Jan 16, 2025 at 3:00 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    You're probably ok. You said "I drove the truck mainly on highway 60-80mph in the cold weather for roughly 2 weeks".
    Without knowing where you are and what "cold weather" means as far as actual temperature can be very different.
  6. Jan 16, 2025 at 3:02 PM
    MarlonB54
    Fishaholic
    New Jersey December temps so 20°F- 45°F
  7. Jan 16, 2025 at 7:08 PM
    abhamber
    abhamber Well-Known Member
    Aman
    Alberta, Canada
    2018 BBP Tacoma TRD Sport DCLB
    I wouldn't worry about it either. I've tracked my transmission oil temperature during my 30 mile highway commutes (at 60mph and between 32F-40F temperatures) and the transmission temperature barely breaks past 170F. I'm stock. I have a soft canopy and carry about 200lbs of extra weight in the bed.
  8. Jan 16, 2025 at 7:10 PM
    545 Well-Known Member
    2015 Access Cab
    Yeah, you are probably fine
    August towing 5k? Ehhhh
  9. Jan 16, 2025 at 7:13 PM
    Clearwater Bill
    Billy
    Largo Florida
    It's fine.
    But a drain and fill might make you feel better when the fluid comes out nice and red
    shakerhood and MarlonB54[OP] like this.
  10. Jan 18, 2025 at 8:06 AM
    MarlonB54
    Fishaholic
    Yea but your trans is being cooled by the radiator
  11. Jan 18, 2025 at 8:07 AM
    MarlonB54
    Fishaholic
    When they flushed and refilled they said the fluid came out normal so thats why i just trusted. I’ll be carrying on then
  12. Jan 18, 2025 at 8:16 AM
    oldtimertoyota
    oldtimertoyota Well-Known Member
    New Mexico
    2009 4X4 Double Cab-1986 2wd Pickup Orig own
    I own a 2nd gen but I just wanted to add that I think you’ll be fine, at times I feel like I have little quirks with my transmission and I’ve had regular maintenance and no big repairs so I think you may just be overthinking things because of what happened
    MarlonB54[OP] likes this.
  13. Jan 18, 2025 at 6:14 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    The radiator's primary job, as I see it, is to reduce the amount of time the transmission is cold - the radiator HEATS the ATF initially, and then later cools the ATF; if required. In your case of driving in the cold - cooling was probably not required.
    I don't see how a body shop would know what is "normal" for a Tacoma.
    I do agree with the others that you most likely have no problem.
    abhamber likes this.
  14. Jan 18, 2025 at 6:56 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    Nothing like that has ever happened to me and my transmission is fine so i think you're gonna be fine. Everything is fine.
    dryheat likes this.
  15. Jan 19, 2025 at 3:22 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Your Tacoma has been tested to climb a constant grade in 100F heat towing 6900 lbs without overheating the tranny. In part that is because of the transmission cooler, but if you were just tooling around town a few miles, I’m guessing you are fine.
    https://www.motortrend.com/how-to/1502-sae-j2807-tow-tests-the-standard/
    I’m not an automatic transmission expert, but I am aware that the torque converter is a very lossy system that converts kinetic energy to heat, but otherwise an automatic transmission is no less lossy than a manual transmission. So as long as you were not overworking your torque converter (towing, stop and go traffic, rock crawling, drag racing) you are probably ok. And even so, you might have only caused slight more wear on the transmission and/or the transmission fluid.
    Don’t let yourself worry something that might not matter in the long run and you cannot do anything about after the fact.
  16. Jan 19, 2025 at 3:52 PM
    dryheat
    dryheat Well-Known Member
    Correct me if I'm wrong but didn't 2020+ rid of the tranny cooler?
  17. Jan 19, 2025 at 4:24 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    Yes it did. The the radiator still keeps the trans fluid temp at bay if it gets hot
  18. Jan 19, 2025 at 4:55 PM
    gudujarlson
    Minnesota
    That has been discussed a lot and my conclusion is that they got rid of a cooler that was external to the radiator, but one still exists inside the radiator. I have never took a deep dive, because I have a manual transmission. Also the tow rating did not change, except that in 2019 there is no mention of a “tow package” that affects the tow rating.
  19. Jan 19, 2025 at 5:58 PM
    I-Give-Up
    I-Give-Up Well-Known Member
    West Phoenix, AZ
    2023 Ice Cap Tacoma TRD
    Meso spare fuse holder. Aluminum gas cap holder. Genuine Toyota bed lights. Bed molle racks. Ammo case storage under hood. In-bed spare tire. Automatic underhood lights. Gooey glurp on frame.
    Your conclusion is correct. The external transmission cooler got deleted circa 2020, even with the so-called trailer tow models. FWIW, I bought and retrofitted one to my 2023. After that date, only the transmission cooler mated to the main radiator was used.
    As for the OP running without a radiator that has the internal cooler, I have to wonder how they managed to find one "by accident." Some shops try to cheap out on a customer hoping they won't notice. inter driving without the internal radiator cooler is unlikely to be a problem, but it's good it got caught. Might be good to drain and refill the pan before summer.
