Transmission doesn't want to change gears in Drive (p0773)
Discussion in '1st Gen. Tacomas (1995-2004)' started by crodrl, Nov 17, 2023.
  1. Nov 17, 2023 at 10:13 AM
    crodrl
    crodrl [OP] Member
    After changing the shifter bushings and removing the shifter assembly from a 3.4l prerunner. It does not want change gears in Drive. It changes gears in Low and 2nd respectively.
    When I removed the shift assembly, I accidentally moved the shift lever a couple of notches next to the transmission. Maybe this caused it?
    It's throwing a p0773 code too.
    I'm lost right now. How do I go about this?
  2. Nov 17, 2023 at 3:29 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
