Transmission Drain and Fill vs Flush
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dlakerguy13, Sep 6, 2018.
  1. Jan 8, 2019 at 1:15 PM
    #41
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Not sure how a 30 degree drive slant compares to my Big Harbor Freight 3 ton with the truck lifted as high as the jack will take it.
    Not a bad idea to measure what came out for a refill qty., but you want to pour more than that back in for the level check strategy to work. If you were under-filled to begin with, nothing will come out. If you were right on the money before the change, you'll get the slight trickle of fluid(very small thin line, but consistent). I wouldn't bet $$$ on that, but who knows?
    Measure what you drained then add 12-16 oz. to that. I'm assuming that if you were underfilled, it was not by more than 12-16 oz.
    Benny123[QUOTED] likes this.
  2. Jan 8, 2019 at 1:26 PM
    #42
    Benny123
    Benny123 Kid from the late 70s
    Ben
    South Charlotte, NC
    2005 Speedway Blue Tacoma AC V6 TRD Off Road 4x4
    Replacing everything worn, broken, and rusted.
    Thank you. Yeah from what I've read, it appears that doing a few drain and fills over a month is safer than a single flush in my scenario. Allows atfs to mix a bit.
  3. Jan 8, 2019 at 1:46 PM
    #43
    Benny123
    Ben
    South Charlotte, NC
    Just a bit more information. About 6 months ago I had an oil cooler line rust and start leaking ATF. At that time it was dealer fixed and ATF was brought up to level. Additionally when I had a recent head gasket replacement, the engine came out of the bay, some of the ATF was replaced at that time. I suspect none of this was over, say, a few quarts. However, some of the ATF has in fact been replaced.
  4. Jan 9, 2019 at 3:36 AM
    #44
    gearcruncher
    Canadain bumper technician
    Drop the pan , inspect the magnets , drop the filter and check inside the filter for particles .
    Never flush a transmission without dropping the pan first and that is regardless of the mileage . Every Tacoma has different contamination levels inside the transmission .How can you possibly know whats laying in your pan and filter ?
    How can anyone else know whats laying in your pan and filter ?
    I would not risk flushing all that crap laying in your pan through your valve body .
    I am basing this decision on the 4000 cars and trucks I have perfomed transmission services on over the years.
    If everything was " SPOTLESS " inside the pan and filter , go ahead and flush the rest of the fluid thats remaining in the torque converter , valve body and cooling system .
    If the magnets are full of metal contamination , just put the pan back on and fill the pan . Do not flush
    If the filter showed signs of plastic or alluminum , just put the pan back on and fill the pan . Do not flush
    If the pan showed signs of brass in the bottom of the pan , just put the pan back on and fill the pan . Do not flush
  5. Jan 9, 2019 at 4:13 AM
    #45
    Benny123
    Ben
    South Charlotte, NC
    gearcruncher likes this.
  6. Jan 10, 2019 at 11:31 AM
    #46
    Benny123
    Ben
    South Charlotte, NC
    Need some last tips on doing this. Planning for tomorrow.
    1. Does anyone slip the bolts into the pan/gasket to help keep it aligned before re install?
    2. Any good object to sit it so it's just under the tranny while you start the bolts ?....was thinking maybe an old milk crate or box.
  7. Jan 10, 2019 at 11:41 AM
    #47
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    I flushed mine at 125K and I have had no issues 10K miles later. I dropped the pan and cleaned the magnets/replaced the filter as well. It shifts noticeably smoother now. I would suggest doing a full flush based on my sample of 1, lol.
    SR-71A, eherlihy and Benny123 like this.
  8. Jan 10, 2019 at 11:50 AM
    #48
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    I have a neighbor who has a screw loose. Not sure if it helps here.....
  9. Jan 10, 2019 at 2:41 PM
    #49
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    Really people - just don’t use a powered flush for changing transmission fluid. Drain and fill (several times using the return line) to get the full 12 or 13 quart capacity changed. You can drop the pan if you want (I do it every other change).
    The process is super simple and the temp check procedure is easy whether you jump it or use a obdII reader. It’s really not that complicated and about as difficult as doing a full diff/TC fluid change.
    A couple beers, some tunes, and maybe a helper?
    TacomaSport86 and Benny123 like this.
  10. Jan 10, 2019 at 2:45 PM
    #50
    Benny123
    Ben
    South Charlotte, NC
    Appreciate that. I gotta say just did the temp check procedure on a dry run. It's quite simple, way easier than programming a keyfob.
  11. Jan 10, 2019 at 2:50 PM
    #51
    Lester Lugnut
    In my experience, that's easier to do if the gasket is rubber-like. If the gasket is more like cork/felt, the bolts may not all keep their place if you try to pre-load all of then into the pan with the gasket in place. Won't hurt to try.[/QUOTE]
  12. Jan 11, 2019 at 12:09 PM
    #52
    Benny123
    Ben
    South Charlotte, NC
    Just did the drain and fill. Twice. One for the Taco, one for the 4runner.
    Went well. Some pointers.
    1. New transmission fluid looks just like arterial blood, bright red. Though in a thin stream old and new look very similar. Dont assume its good till you do a full drain, mine got much darker as the drain progressed.
    2. Old fluid can look like venous blood, or even worse, stoma ooze, dark brown.
    3. If you park on a great slant 30+ degrees, you will remove 4 quarts easily, just refill before starting your truck and leveling it. No need to jack then.
    4. If youve never done this before, or arent sure if its been done, add extra 8-16 oz. I was underfilled. Otherwise, the AT temp check procedure will be a waste of time.
    5. If youre considering dropping the pan and want to know the bolt size, its 6mmx15mm (10mm heads), they have them at Lowes. Probably dropping the pan next time.
    6. Also count the bolts. Some have 19, some have 20, they have different gaskets, and without a doubt, Autozone and Amazon will recommend the opposite one.
    7. When youre pumping ATF in, use clean lines. You can also buy them at Lowes in 10 ft bundles. Dont get old gear oil in there.
    8. If you have a tiny allen wrench instead of a socket allen, use a pipe cheater to open the check plug.
    9. Dont buy a shitty torque wrench. I got an inch lb torque wrench from HF and noticed it wasnt clicking. Fortunately I tested on a workbench bolt first. It broke the head off at 5 in lbs. I then tried it on a lug nut for fun, and it didnt even click at 83 FT LBs. Needless to say it went back to HF, and I got a nice one. And it ACTUALLY clicks!
    10. The hardest part of the whole procedure, without a doubt is lining up the threads on the fill plug when youre done. JC it could not be any more awkward.
    11. Have beer on hand for completion.
  13. Jan 11, 2019 at 12:34 PM
    #53
    TheDevilYouLove
    Marylandistan
    If you drop the pan, note that torque specs are in INCH pounds. NOT foot/lbs!!
  14. Jan 11, 2019 at 12:46 PM
    #54
    Benny123
    Ben
    South Charlotte, NC
    Exactly. I made a correction for folks over at t4r.org who posted the procedure in ft lbs. If I would have used that torque wrench from HF would have been in deep.
  15. Feb 18, 2019 at 11:42 AM
    #55
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    I have a 09... It shifts but it seems like my transmission working harder on the shift. Especially 2 to 3. I have 162k miles on it. I have to say, I have never done a service on it. I recalled on the manual that auto transmission is life of the vehicle but if you tow. Its better to do the transmission service on it. what do you guys think? thx
  16. Feb 18, 2019 at 11:59 AM
    #56
    TheDevilYouLove
    Marylandistan
    I did mine for the first time at 125K and everything went fine. I dropped the pan and changed the filter and cleaned the magnets, in addition to a full flush. If I were you, I would go for it. Maybe do a pan drain first and make sure the fluid is not too terrible looking.
  17. Feb 18, 2019 at 12:10 PM
    #57
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    hmm, I would need to bring it to a mechanic... I was thinking bringing it to a Lee Myles place up the road.
  18. Feb 18, 2019 at 5:41 PM
    #58
    Benny123
    Ben
    South Charlotte, NC
    No matter who does it, drop the pan and clean the magnets before flushing or you will regret it. Just ask @gearcruncher
  19. Feb 18, 2019 at 6:06 PM
    #59
    gearcruncher
    Yes sir .
    Removing the transmission pan first for an inspection is the proper procedure when servicing a transmission .It also takes longer and makes for a more in depth service .
    Never take the chance of flushing without removing the pan . The bottom of the pan is the septic tank of the transmission
    Can you see whats in your pan before you remove it ? Some shops risk it all the time and they all get caught ...period
    I dont care if the transmission is brand new , if you flush without removing the pan , you risk flushing crap through your valve body and jamming up all the valving .
    I dont have 5 extra hours to begin messing with your valve body when you came in for a professional transmission service .
    How many cars and trucks have I flushed ? Probably 4000 to 5000 over the years .
    The pan comes off first
    Those speedy lube shops that take the risk have kept my pockets lined for many years :spending:
    Hyperion, DGXR and Benny123[QUOTED] like this.
  20. Feb 18, 2019 at 6:43 PM
    #60
    gearcruncher
    Just reading this now .
    Fluid life use to be 100k
    A couple years ago Toyota dropped that number to 60K intervals .
    Some reading for you when you get a chance .
    Maybe we can figure out that 2-3 shift ....Catch it now before it gets worse $$$$$$
    https://www.tacomaworld.com/threads...th-pics-for-second-gen-4-liter-trucks.289913/
    Hyperion likes this.
