Transmission? Driveshaft?
Discussion in 'Technical Chat' started by linkfeeney, Feb 18, 2019.
  1. Feb 18, 2019 at 10:43 AM
    linkfeeney
    linkfeeney [OP] Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    Hello,
    I have a 09 Tacoma... the auto transmission seems rough on the shift. Especially from 2 to 3. It shifts but I can hear the engine and transmission working hard and loud before it shifts. I have to say, I have never done a transmission fluid change. The manual said its life of the truck unless towing. I haven't done anything towing on it. Im not sure if I should have the fluid changed or maybe the transmission is wearing out? I have the truck looked at last week at the dealer for the U-joints warranty. They said it was fine.... could it be the drive shaft? It doesn't sounds like it. FYI, I have 162k miles on it.
    what do you guys think?
    thx
  2. Feb 25, 2019 at 5:45 AM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Trans fluid could use changing due to high mileage but 99% that will not fix your problem. We get that a bit at my dealer "I want to do a trans flush to fix a trans issue" requests, we tell them we can do it if they want but would rather do diag on the trans for issues.
  3. Feb 25, 2019 at 7:35 AM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    Hello,
    I took to a mechanic by me. Their specialty is transmission and the heavy work. He drove it and said it seemed fine to him. But he recommended a drain and fill and not a flush. It would help prolong it. So they changed the filter and 5 qts of fluids. When I shifted into Drive, its alot smoother and changing gears seems to be the same. Yes, it needed a fluid change with 162k miles. I want to keep this vehicle for another 10 yrs, by then my son would stay driving. He can keep it. (hopefully)
    wilcam47 likes this.
  4. Feb 27, 2019 at 11:57 AM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Any update on this?
  5. Mar 2, 2019 at 9:45 AM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    Hello,
    It seems fine, but it feels like the truck needs power for the transmission that's why it seems to struggle or shifting more. But the mechanic did a code check and didn't see anything wrong with the engine or transmission... maybe I need a new air filter? I changed that 2 yrs ago... or maybe fuel filter?? I dont know... next time I'll get a manual trans. If I need a clutch, at least that obvious.
