Transmission Filter
Discussion in '1st Gen. Tacomas (1995-2004)' started by toto, Aug 26, 2009.
  1. Aug 26, 2009 at 6:08 PM
    toto
    toto [OP] Member
    PRK
    96 2WD 2.4L
    Hello All,
    First time poster long time lurker here.
    I need help. I have 96 2WD 2.4L automatic.
    Does the tubing in front of the filter come off?
    Is that just a press fit? Do i just pry it with a screwdriver?
    Please see pix.
    Thanks for your help.
    Toto
  2. Aug 26, 2009 at 6:10 PM
    98tacoma27
    Ben
    Not Beech Creek
    Welcome to TW!
    You should be able to just pull it out. Grab it at the bends and pull straight down.
  3. Aug 26, 2009 at 6:15 PM
    toto
    toto [OP] Member
    PRK
    96 2WD 2.4L
    OK thanks a lot for you help :)
  4. Aug 26, 2009 at 6:18 PM
    98tacoma27
    Ben
    Not Beech Creek
    The FSM says you can use a large screw driver to pry them out, just don't bend/damage the pipe.
  5. Aug 26, 2009 at 6:19 PM
    toto
    toto [OP] Member
    PRK
    96 2WD 2.4L
    I'd be careful
