Transmission flaring meets Temporary fix.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by harrycary, Jul 25, 2017.
  1. Jul 25, 2017 at 4:20 PM
    harrycary
    harrycary [OP] Well-Known Member
    Harry
    2016 Tacoma TRD Off Road
    Hi all. I see a lot of people are having trouble with the transmission flaring when shifting from third to fourth gear on their first run of the day. A friend of mine had the same problem. It was bad. I checked his transmission fluid, the manual way, and the level was spot on. Having an idea that there may some air getting introduced into the hydraulics when the fluid contracted, I overfilled his transmission 1/2 quart. He hasn't has a flair since. I wonder if this is a good solution or if it could cause any problems.
  2. Jul 25, 2017 at 4:27 PM
    harrycary
    Harry
    Has anyone else tried anything like this?
  3. Jul 25, 2017 at 4:37 PM
    petr321
    petr321 Well-Known Member
    Petr
    San Diego
    2018 DCSB OR
    to get a accurate reading the trans temp has to be 102 degrees. the the temp of the fluid off your reading was off
  4. Jul 25, 2017 at 4:39 PM
    harrycary
    Harry
    I was at 105 degrees when I checked the fluid.
  5. Jul 25, 2017 at 4:39 PM
    petr321
    Petr
    San Diego
    2018 DCSB OR
  6. Jul 25, 2017 at 4:40 PM
    harrycary
    Harry
    Thanks for looking out though.
    petr321[QUOTED] likes this.
  7. Jul 25, 2017 at 4:41 PM
    James_Bond
    James_Bond Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
    @gearcruncher is there any downside of overfilling an AT with the correct fluid?
  8. Jul 25, 2017 at 4:42 PM
    petr321
    Petr
    San Diego
    2018 DCSB OR
    I think so, excessive pressure on the main seal
  9. Jul 25, 2017 at 4:42 PM
    harrycary
    Harry
    Jus an FYI: the transmission was an ac60F
  10. Jul 25, 2017 at 4:43 PM
    harrycary
    Harry
    Hi. Are you a trans or Toyota tech?
  11. Jul 25, 2017 at 4:44 PM
    petr321
    Petr
    San Diego
    2018 DCSB OR
    no but looked into this with my old truck when I was doing a tranny flush and looked up some info and thats the info i ran across.
  12. Jul 25, 2017 at 4:45 PM
    harrycary
    Harry
    Interesting. Thanks!
  13. Jul 25, 2017 at 5:21 PM
    harrycary
    Harry
    IS gearcruncher a Toyota tech?
  14. Jul 25, 2017 at 5:22 PM
    James_Bond
    Southern California
    '16 TRD Sport DCLB
    All stock
    IDK, but he knows a TON of things about Toyota transmissions and transmissions in general.
    harrycary[QUOTED][OP] likes this.
  15. Jul 25, 2017 at 5:47 PM
    harrycary
    Harry
    Thanks for the heads up. I am looking forward to some good information.
  16. Jul 25, 2017 at 6:04 PM
    harrycary
    Harry
    It seems this gearcruncher knows what is wrong with this transmission. It was s exactly what I thought.
  17. Jul 26, 2017 at 5:28 AM
    harrycary
    Harry
    I checked this morning and my truck has the same flare when shifting from third to fourth gear. This sucks.
  18. Jul 26, 2017 at 5:40 AM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    Only issue I've heard of on over filling (and I'm thinking more like a quart or two over) was it could cause the fluid to foam and possibly starve the VB at times.
  19. Jul 26, 2017 at 5:57 AM
    harrycary
    Harry
    Thank you for your input!
    1bad2k[QUOTED] likes this.
  20. Jul 26, 2017 at 6:10 AM
    harrycary
    Harry
    http://www.sonnax.com/parts/2277-o-ringed-end-plug-kit
    This is a good read. While this in not an AC60F transmission (the one in the TRDOR) It is a similar Toyota valve body, and I think the principles are the same. I bet air is being drawn in through the stock bore end caps as the transmission fluid contracts due to cooling down. I would bet that the Rev1 TSB transmission software patch runs some code to try to purge out the air, that got drawn into that circuit, before the valve body relies on that circuit to control the transmission's function. Just my speculation..... Any thoughts @gearcruncher or any other whizzes?
