Transmission fluid capacity on a V6 1996 Toyota Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by toyotataca, Jul 20, 2015.
  1. Jul 20, 2015 at 5:55 PM
    toyotataca
    toyotataca [OP] New Member
    I have a Toyota Tacoma 1996 and has a manual transmission.I am replacing the transmission fluid but I don't know how many quarts do I need to replace my transmission fluid? The engine size is 3.4L
  2. Jul 20, 2015 at 6:59 PM
    high n mighty
    high n mighty Well-Known Member
    Oshawa Ontario
    01 camo taco
    2.6L 2wd
    2.2L 4wd
  3. Jul 20, 2015 at 7:17 PM
    toyotataca
    You are awesome! Thank you!!
  4. Jul 21, 2015 at 7:47 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    depends if you are flushing and replacing it all or just swapping whats in the pan. have double that amount on hand if you are replacing it all by flushing or after a rebuild because the torque converter and lines all must be refilled and purged of air, unlike when doing a normal oil change
