Transmission Fluid Change Dilemma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mtntacoVA, Oct 17, 2024.
  1. Oct 17, 2024 at 11:29 PM
    mtntacoVA
    mtntacoVA [OP] Member
    13 Taco, 24 4Runner
    Alright, so this pains me to post this bc I generally pride myself on keeping up with maintenance but excuses, etc.
    Anyway, I have a 13 Taco with 127k miles. No issues other than the valve cover leak.
    I had the transmission flushed and refilled with royal purple at around 50k.
    Now, after driving 78k miles and the “oh shit, I should have done this 27k ago” moment, I’m debating on the best course of action.
    My thought is drain and fill with either (1) royal purple to keep it consistent or (2) go back to Toyota fluid.
    only concern with going back to Toyota atf is mixing fluids.
    any advice is appreciate or insights on if I should consider some other COA bc of the extended time with the current fluid. No issues at all with shifting.
  2. Oct 18, 2024 at 5:26 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Will you be doing the work, or will a shop? If you are Id drop the pan, clean the magnets, put in a new strainer & gasket, and refill.
    I dont think the fluid matters too much. As long as the fluids are both WS compatible. If you are worried do a few drain and fills back to back over the course of a few weeks.
    mtntacoVA[OP] and Jakerou like this.
  3. Oct 18, 2024 at 5:53 AM
    Jakerou
    Jakerou Well-Known Member
    Jake
    MA
    2023 Celestial Silver SR5 DCLB
    I would NOT do a flush. Drain and fill- so you should stay with whatever fluid you’ve got in there. Don’t over think it.
  4. Oct 18, 2024 at 6:14 AM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    Drain and fill. You are fine.
  5. Oct 18, 2024 at 6:36 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Do whatever helps you sleep better at night. At the end of the day it doesn't matter. I've driven several million miles in over 50 years of driving and have never changed the AT fluid in any vehicle. Currently just under 700,000 combined miles sitting on the driveway with the factory fluid in them. The Tacoma has the most miles at 251,000, but only one is under 100,000.
  6. Oct 18, 2024 at 6:39 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    This is advice.
  7. Oct 18, 2024 at 6:58 AM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    Unless you are towing on the regular (like majority of miles), 78k is not a lot of miles between services.
    The manual says change it every 60k if you're towing a lot (or otherwise heating the fluid).
    I'd say do whichever makes you feel better.
  8. Oct 18, 2024 at 4:10 PM
    mtntacoVA
    13 Taco, 24 4Runner
    Thanks all - not doing a flush at this mileage, just drain and fill.
    Appreciate the advice
    TnShooter likes this.
