Transmission fluid change question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mquibble, Mar 16, 2023.
  1. Mar 16, 2023 at 8:00 AM
    mquibble
    mquibble [OP] Well-Known Member
    Michael
    2021 TacomaTRD Pro
    I’ve already drained and refilled my transmission and performed the routine at temperature to ensure the level is correct. My question NOW is on subsequent changes, what if I caught and measured how much was removed when I execut the approximate 4 quart drain and refill, and simply refill the tranny with that amount? Would this be acceptable to do now because “I” performed the last fluid change and confirmed the level was correct?
  2. Mar 16, 2023 at 8:01 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    unless you develop a leak... then you wouldnt know the true level. food for thought. Ski
    mquibble[OP] likes this.
  3. Mar 16, 2023 at 8:04 AM
    19992021Taco
    19992021Taco Well-Known Member
    1999 and 2021 Tacoma
    The fact that Toyota gave us no tranny dipstick is asisnine!!
    helix66, boston23, JmsWms and 4 others like this.
  4. Mar 16, 2023 at 8:27 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    I agree above. It should be easier to change transmission fluid. The idea of measuring through an overflow once the transmission fluid is at a specific temperature. It’s like porridge not too hot not too cold. Anyways having my fluids changed today. Hoping it’s done right… holding onto bill in case.
    zoo truck and Stevie17 like this.
  5. Mar 16, 2023 at 8:28 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    I would still do the proper level check.
  6. Mar 16, 2023 at 11:39 AM
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    The drain and refill amount is 3.5 quarts as per Toyota. When I do mine , Im draining it stone cold, and pumping new fluid in stone cold. I will measure what comes out for giggles.
  7. Mar 16, 2023 at 3:13 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    do you remove the pan or just drain plug to get the 3.5 qt's? i am going to do mine and will not mess with the pan. i might try and stick a tube thru the fill hole after draining and run it in to the bottom of the pan and see if i can suck anymore out
  8. Mar 16, 2023 at 3:18 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    If you attempt this, make DAMN SURE you can remove the fill plug before draining.
    Ory69, KY_Rob, Toy_Runner and 2 others like this.
  9. Mar 16, 2023 at 3:37 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    Yea..and it is kind of up high a bit hard to get at. same with doing the diff's.
    what i will not do is fill it with the engine running like some videos say to do. no way will i be under my truck while it is running.
  10. Mar 16, 2023 at 3:45 PM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Not that big of a deal……try standing next to an aircraft engine running……always unnerving
    cryptolime and SpeySquatch like this.
  11. Mar 16, 2023 at 3:47 PM
    Bishop84
    Bishop84 Well-Known Member
    The idea is, it's an overflow style. So intentionally put too much in. Pushes out the unneeded.
    If you do a measure and refill its not ideal, but it certainly won't break anything.
    Dip sticks were very subjective and manufacturers wanted people to stop messing with them.
    I prefer the overflow style. I despise dip stick transmissions.
    SR-71A, Winerocks, hiPSI and 3 others like this.
  12. Mar 16, 2023 at 5:08 PM
    AM6217
    So if my truck is is cold and I drain it. Then fill it till it weeps from the over flow, Im going to assume its filled to the correct level. To be honest I don't even care if its perfect. It'll be better than half the Tacomas on the road that get zero trans maintenance.
    kahanabob likes this.
  13. Mar 16, 2023 at 5:23 PM
    mquibble
    Michael
    2021 TacomaTRD Pro
    No. If you drain it cold and refill it with the same measured amount you will be good. If you drain it cold and refill until it runs out through the overflow tube you have just put in MORE fluid and will be overfilled.
  14. Mar 16, 2023 at 5:25 PM
    AM6217
    10-4 quibble man
  15. Mar 16, 2023 at 6:48 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    i expands when it gets hot. do like you described then warm up the truck to 1/4 hot then check the overflow drain again.
    a little may come out. that's what i do. but that's just me.
    auskip07 likes this.
  16. May 5, 2023 at 8:03 PM
    gasganofj60
    gasganofj60 Well-Known Member
    87 FJ60 & 21 TRDOR
    What is the temperature range it needs to be in to remove the standpipe plug?
  17. May 5, 2023 at 10:10 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  18. May 6, 2023 at 4:45 AM
    ThreeBeers
    ThreeBeers Well-Known Member
    Ron
    2020TRDOR
    I wish if they were going to do away with the dip stick they would have built a sight glass into the transmission case
    Bronxguy, Stevie17 and mquibble[OP] like this.
  19. May 6, 2023 at 11:07 AM
    AODRN
    AODRN Well-Known Member
    STL
    2019 Quicksand DCSB Sport
    SCS 17x8.5 -10 offset. 285/70/17. Iron Man Foamcell Pro stage 2 set at 2.5". 4.88 gears. Rear E-locker. KDMax Tuned
    I've been curious about how much the fluid actually expands. I did the change cold and refilled to it started coming out the overflow. When I got it up to temp there was negligible fluid over what came out cold. Is 10ml of fluid really going to make a difference? I'm really asking. This seems like the difference between textbook and actual practice to me though. Something for the OCD to focus on
  20. May 6, 2023 at 12:00 PM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I have heard from a few Toyota techs that cold to hot can differ by about 1/4 of a quart
