transmission fluid (change vs dropping pan)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KeithF40, Aug 11, 2022.
  1. Aug 11, 2022 at 4:30 PM
    Benny22
    Benny22 Well-Known Member
    20Tacoma
    Money to burn.
    I do it ever other year for around $20.
    https://www.rockauto.com/en/moreinf...agq6AK4a/lRbievAYSI7hRZAjQAUOxqeiBHBR6ys3y+1u
  2. Aug 11, 2022 at 4:40 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    You really need to work on your rhetoric.
  3. Aug 11, 2022 at 5:06 PM
    KeithF40
    KeithF40 [OP] Well-Known Member
    Keith
    2019 Black Toyota Tacoma SR V6 4x4 Double Cab
  4. Aug 11, 2022 at 5:06 PM
    KeithF40
    Keith
    is there a filter to actually change or no? i dont remember.
  5. Aug 11, 2022 at 5:10 PM
    Bob1971
    Bob1971 Well-Known Member
    Tim
    KY
    White 2020 Trd OR
    Bed cover, step bars, SCS SR8 wheels
    Totally off the subject…I truly apologize to the OP but what the heck happened to that truck in the pic! Seriously I can’t come up with a cause.
    Mully[QUOTED] likes this.
  6. Aug 11, 2022 at 5:11 PM
    saint277
    saint277 Vigilo Confido
    Looks kinda like whistlin diesel's work....
    Bob1971[QUOTED] likes this.
  7. Aug 11, 2022 at 5:24 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    The AT filter in a 3G is just a wire mesh, it doesn’t require changing.
    SLeeper512 and G8R_Taco like this.
  8. Aug 11, 2022 at 6:31 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Spacer lift.
  9. Aug 11, 2022 at 6:34 PM
    Benny22
    20Tacoma
    correct.
  10. Aug 11, 2022 at 6:37 PM
    saint277
    not always true, my 3.5at definitely had a real filter with paper or synthetic filter media in it. Not a screen that wouldn't get clogged, you definitely should drop the pan and see whats in there. This is the filter in my pan, you can see the not metal mesh filter media in it.
    Stocklocker[QUOTED] likes this.
  11. Aug 11, 2022 at 6:38 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I do this every time I change the oil pretty much.
  12. Aug 11, 2022 at 6:48 PM
    Stocklocker
    17TRDORDCSBAT
    interesting. I guess I made the mistake of believing what I read on TW? I will have to do my own research. I will leave my 1st post up as a lesson to others.
  13. Aug 11, 2022 at 6:50 PM
    saint277
    Ya rock auto lists 2 filters and because of this place a bought the metal screen one, because everyone knows the the 3rd gens have a metal screen. I was quite upset when I got my pan off.
    This was the one I incorrectly bought.
  14. Aug 11, 2022 at 6:54 PM
    Stocklocker
    17TRDORDCSBAT
    So is this whole “metal mesh screen” idea just fake news, or do some 3Gs actually just have a metal screen and some have a proper filter?
  15. Aug 11, 2022 at 7:01 PM
    #35
    saint277
    Rock auto lists the mesh filters for 2016s only, along side the proper filter. So my guess is that some of the early 2016s had the mesh filters for some reason and the rest have a proper filter, but those early 2016s established the "fact" that 3rd gens only had a mesh filter. Not really fake, but not completely true either.
    Rainoffire, G8R_Taco, jmneill and 2 others like this.
  16. Aug 11, 2022 at 7:06 PM
    #36
    Lt. Dangle
    Ohio
    G8R_Taco and Stocklocker like this.
  17. Aug 11, 2022 at 7:09 PM
    #37
    Stocklocker
    17TRDORDCSBAT
    So did they also go from a metal ‘filter’ housing on the 2016 to a plastic one thereafter?
  18. Aug 11, 2022 at 7:17 PM
    #38
    saint277
    Ya the new design is plastic. Would prefer a metal housing but the one I pulled had 90k on it and it didn't show any signs of distress.
  19. Aug 12, 2022 at 6:37 AM
    #39
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    I believe the intent of the comment was to recognize a drain only empties approximately 3 quarts of an 11 quart system. Refilling and cycling through the gears mixes the new fluid with that captured in the torque converter.
    alegerlotz likes this.
  20. Aug 12, 2022 at 8:14 AM
    #40
    SLeeper512
    SLeeper512 Well-Known Member
    Sam
    2021 SR5 DCLB Tacoma white with red topper with tow pkg
    Yes, sort of. On mine at proper fluid level I only get 2.5 quarts out. However, when I did the "flush" I drained out the 2.5, put in 4, went through the gear shifting sequence, let cool, then drained added back another 4 quarts, repeat shifting sequence, drain, add in 4 quarts, shift, then "drained" while running about 1.5 quarts from fill cycle to get to proper level (at approx 105*).
    p.s. My spill & fill sequence, drain about 2.5 quarts, add 4 quarts, do gear shifting.... let cool a bit then get to proper level, draining about 1.5 quarts.
    mquibble likes this.
