Transmission Fluid Change vs Flush?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fore, Dec 30, 2009.
  1. Dec 30, 2009 at 11:46 AM
    Fore
    Fore [OP] Well-Known Member
    07 PreRunner
    Does anyone know if you have the Toyota stealership change your ATF fluid do they do a complete flush of the transmission my hooking it up to a machine or do they just remove whole panthe plug and refill method like DIY mod. The reason I ask is you still have allot of ATF left in the lines and else where that can't be drained by the plug method only. Or am I wrong here!
  2. Dec 30, 2009 at 1:21 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    You are correct. The drain and fill procedure doesn't remove the entire capacity of the AT.
    Not all dealers have the flush equipment so you will have to ask the establishment before you make the appointment.
    Some individuals and mechanics recommend against flushing as it stirs up debris and forces it through the system and valve body - especially on vehicles with higher mileage that have never been serviced. This results in damage to the AT and if serious enough, a rebuild. That said however, hundereds of vehicle get flushed everyday across North America and I would think the percentage of vehicle that receive damage is very, very low.
    IMHO a drain and fill at recommended intervals is all that's needed. No the entire contents are not drained, but this is taken into account during the engineering of the AT and the establishment of the ATF service intervals.
    You'll get varying opinions on this, and the mentality is that we are all right regardless of what side of the fence you sit on.;)
    It's your truck and your money - preventative maintenance is key before you rack up too many miles.
  3. Dec 30, 2009 at 3:22 PM
    Fore
    07 PreRunner
    Thanks for your reply. I'm at the 56,000 mile range and I don't think the ATF has ever been changed, I'm the second owner. If I do get it flushed through a machine I would like the ATF switched to a synthetic brand. Does anyone have an opinon on that?
  4. Dec 30, 2009 at 7:11 PM
    mountain lion
    mountain lion Member
    VA
    06 PreRunner
    URD TCAI, MAF Cal, o2 Sim, DT Headers
    Redline D6 or Amsoil ATL low viscosity ATFs are about your only two options as far a true synthetics go for this transmission. If you're doing a full flush, the dry fill is 11.5 qts, so you'll probably need at least 13-14 qts.
    You can do a full flush yourself relatively easily. I should have a write up done w/ pics this weekend as I'm about to do it myself.
  5. Dec 30, 2009 at 7:18 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Some of these flushes are done with chemicals, I would ask first and stay away from these. Try to change the ATF every 25,000 miles and you won't ever need a flush.
    I did this on my 84 Volvo and when I gave the car away it had 265,000 miles and the trans was as smooth as the day I bought it.
  6. Dec 30, 2009 at 7:51 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    i drain an fill mine ever 15k:cool:
  7. Dec 30, 2009 at 8:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    FWIW, The OEM fluid in the Auto 5 speed tranny is an WS Fluid. Its a synthetic.
  8. Dec 30, 2009 at 8:40 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    ^^^yeap^^^
  9. Dec 31, 2009 at 4:56 AM
    fletch aka
    Gary
    Left Coast
    Even better :thumbsup:
  10. Dec 31, 2009 at 5:26 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I thought our AT's were good till 100k?
  11. Dec 31, 2009 at 5:53 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    Cool, I didn't know that.
  12. Dec 31, 2009 at 6:08 AM
    Fortech
    CANADA
    Toyota recently changed the recommended interval to every 60,000 miles.
  13. Dec 31, 2009 at 10:06 AM
    Fore
    07 PreRunner
    Thanks for the good advice. I just called the Toyota stealership and he quoted me $179.99 to do a full flush of the ATF. They also quoted me $149.99 for a full radiator flush. YIKES!!! I think I'll hold out and wait for the guy in this forum to post a DIY full flush of the ATF.
