Transmission Fluid Change?
Discussion in '4 Cylinder' started by dgjones, Feb 12, 2011.
  1. Feb 12, 2011 at 10:10 AM
    dgjones
    dgjones [OP] Well-Known Member
    Portage, IN
    09 Tacoma Reg Cab
    None yet :)
    Hi, 09 Taco. 2.7. 30,000 miles. I would like to change the transmission fluid buy I don't know where to begin or what type to use. Manual mentions nothing about transmission maintenence (except to take to toyato dealer) Can anyone give me the rundown on this??
  2. Feb 12, 2011 at 10:34 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    I am pretty sure the 2nd gen tacos can go longer, at least 50k for the automatics. Check the color of your fluid.
  3. Feb 12, 2011 at 11:19 AM
    dgjones
    Portage, IN
    09 Tacoma Reg Cab
    None yet :)
    I've done some pretty heavy towing with this truck and I want to change the fluid. Where is the drain plug located?
  4. Feb 12, 2011 at 1:57 PM
    VermonterLost
    VermonterLost Well-Known Member
    Devin
    Castleton, VT
    2014 F150
    Manual or Automatic? Kind of important.
  5. Feb 12, 2011 at 4:08 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
  6. Feb 12, 2011 at 11:00 PM
    4cyltacoma
    4cyltacoma Well-Known Member
    Reagan
    Fresno, Ca
    06 Tacoma SR5 4Cyl 4x4
    AFE CAI, Black Housed Headlights, In Channel Window Visor, Bug Deflector, Black Side Step Tubes, Blacked out emblems
  7. Feb 13, 2011 at 4:14 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    30k miles although I changed all my fluids over to mobil one syntho when I purchased my 2011 new.
  8. Feb 13, 2011 at 10:13 AM
    dgjones
    Portage, IN
    09 Tacoma Reg Cab
    None yet :)
  9. Feb 16, 2011 at 10:06 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    aFe Pro Dry air filter, magnetic oil drain plug, synthetic seat covers, steering wheel cover
    I bought some T-IV fluid recently and will be doing a drain & fill on my 2006 4-cyl auto trans (almost 60k miles). I don't have a pump for refilling through the fill hole, but I have a medium funnel that fits inside the dipstick tube neck. Is there any reason why I can't add fluid through the dipstick tube? There won't be any grime or dirt in the tube since the dipstick fits snug over the neck.
  10. Feb 18, 2011 at 8:50 AM
    DGXR
    Friend
    Sacramento, CA
    bump...
    I just read in another thread that the 1st gens can add tranny fluid through the dipstick tube, that's great... I just want to know if there is any reason why I cannot add trans fluid through the dipstick tube on my 06 4cyl 4-speed auto (takes T-IV fluid). Thx
  11. Feb 27, 2011 at 6:40 AM
    The Shape
    The Shape Well-Known Member
    Forrest City, AR
    '09 Access Cab A/T 4banger
    It is true that for normal driving conditions the fluid doesn't need to be serviced?
  12. Feb 27, 2011 at 5:06 PM
    frog13
    frog13 Well-Known Member
    Just go by what Toyota advises......all fluids need changed at some point.
  13. Feb 27, 2011 at 5:48 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Not sure what trans you have .If its a manual , its very easy.There is a drain and a fill plug. consult manual for the oil type , socket size ,and oil quantity. Basically you drain the oil from drain plug ,refill the oil on lvl ground until its near the fill plug.
  14. Feb 28, 2011 at 9:14 AM
    DGXR
    Friend
    Sacramento, CA
    I have a 4-speed automatic transmission in my 2006 4-cyl 2wd access cab Tacoma. It requires T-IV fluid. After draining the used transmission fluid, is there any reason I can't add new transmission fluid through the dipstick tube? Anyone?
  15. Feb 28, 2011 at 4:43 PM
    Turp
    Turp Well-Known Member
    Virginia
    02 PreRunner SR5
    K&N panel/ snorkel removed Keyless
    While I have not done this on a Toyota, my Nissan, did require filling from the dip stick and this is common with other makes. There are funnels that work perfectly for this and it drops the fluid into the pan which is where you drained the old fluid from.
  16. Mar 7, 2011 at 9:40 AM
    DGXR
    Friend
    Sacramento, CA
    Did the drain & fill this weekend at 56k miles: fully warm, drained for 10 min, plugged, added 3qt T-IV slowly through the dipstick, drove gently for 10 min (including a short highway run), checked level... turns out it needed about 3.8qt total to reach 'full when hot' on the dipstick. Elsewhere in these forums it says 3.2qt for drain & fill... maybe just my tranny, maybe some are not draining as long or when hot, or something else. It would take about 4qt to reach the level it was at before, which was 1cm above the full/hot mark. The used fluid was a chocolate red color and the new fluid is bright red. It seems to shift slightly smoother and accelerate more easily under normal driving, just more efficient overall power usage.
  17. Mar 7, 2011 at 1:04 PM
    jassco
    jassco Well-Known Member
    Boston
    2008 4runner, UrbanRunner Silver
    This comes from everyone with the v6 auto which has no dipstick(needs pump for ease). 4cyl auto does but it's less common on here, so that is where you heard that from.
  18. Nov 19, 2015 at 7:18 PM
    FlightMedic178
    FlightMedic178 Well-Known Member
    Nate
    Phoenix
    2017 DC OR MT
    Bone stock
    Very old thread revival but figured it might help someone else..
    Did my first transmission drain and fill today (125k miles). I actually got 4.5qt out by jacking up only the front passenger tire super high..
    Replaced with 4.5qt of Toyota type IV and can definitely tell, shifting is much smoother. I actually didn't realize it was shifting abruptly until I did this. Well thanks to previous posts for the guidance!
  19. Apr 30, 2016 at 8:41 AM
    bretts
    bretts Well-Known Member
    Pasadena, TX
    04 single cab prerunner
    Did you refill via the dipstick hole? I just got an 08 and kept seeing these threads showing a 4.0 trans flush. Glad I found this thread. Thanks for the tip about jacking driver side up - the more I can get out at one time the better! Glad I have a dipstick to check, eases my mind
  20. Apr 30, 2016 at 8:46 AM
    FlightMedic178
    Nate
    Phoenix
    2017 DC OR MT
    Bone stock
    Yep dipstick hole works great!
