Transmission fluid change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BCT09, Sep 16, 2011.
  1. Sep 16, 2011 at 1:18 PM
    BCT09
    BCT09 [OP] New Member
    Bobby
    Redondo Beach ca
    Hey guys i have an 09 tacoma and i was wondering how often i should change my transmission fluid. i looked at my owners manual didn't specify! thanks in advanced!
  2. Sep 16, 2011 at 1:32 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Leave it alone, more bad comes from a tranny flush than good.
  3. Sep 16, 2011 at 1:42 PM
    saugus
    saugus Well-Known Member
    There are different requirements for AT, MT, 4x4, hauling. I have 133k on my manual and will be doing the most likely "first" refill.
  4. Sep 16, 2011 at 1:52 PM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    x2. Nothing bad comes from replacing fluid in the transmission unless damage has already been done. I'll be doing my first flush at 60k miles.
    If you do a full flush, I'd do it between 50 - 75k miles depending your driving habits, if you're just doing a drain and refill you might want to do it a little more frequently or closer to every 50k miles.
  5. Sep 19, 2011 at 9:52 PM
    BCT09
    Bobby
    Redondo Beach ca
    alright thanks everyone i appreciate the input!
  6. Sep 19, 2011 at 10:27 PM
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    i called toyota asking for a quote and they said 100k mi WAS what it should be changed at now they saying that "when you have a problem bring it in".... sounds like they just need money lol
  7. Sep 19, 2011 at 10:30 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    I just did the flush at 50k mi. After this I will be doing a 3qt. Drain/refill every 15k mi so I don't have to deal with doing the full flush again.
  8. Sep 19, 2011 at 10:30 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    I just did mine at 81,000....shifts smoother now :spy:
  9. Sep 19, 2011 at 10:41 PM
    Jerez
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    :brianr: asshole :cool:
