Transmission Fluid Change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by N_Colavito, Sep 17, 2021.
  1. Sep 18, 2021 at 5:54 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    If their anything like their washers in the past you should have no issues reusing them. They adhere to the bolt when the bolt is removed. I did serval dozen oil changes on my tundra over the years never replace a single washer. Never had a leak either.
    gearcruncher likes this.
  2. Sep 19, 2021 at 11:06 AM
    willie2
    willie2 Well-Known Member
    Nova Scotia Canada
    4 Banger 5 spd
    About to change tranny and diff oil on my 11 5spd 2wd. I know the diff has an oil level inspection plug and I fill it up to edge of it. Is transmission the same? I expect it is but was just wondering before crawling under. Also calls for 75w85 in diff and 75w90 in tx. Any concerns using 75w90 in both?
  3. Sep 19, 2021 at 11:13 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. MTs have separate drain and fill plugs. If it says 75W85 for the MT in your owners manual, 75W90 will be just fine.
    willie2[QUOTED] likes this.
  4. Sep 19, 2021 at 11:31 AM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
  5. Sep 20, 2021 at 7:31 AM
    N_Colavito
    N_Colavito [OP] Member
    Nick
    2016 Black Tacoma TRD Off-Road 6 M/T
    Borla Cat-Back Exhaust
    The fluid changes are done, no leaks ad of now. Nothing to overthink while doing it I used the washers, cleaned the plugs, and torqued to spec. Thanks for everyone’s input.
    moto932 and tonered like this.
