Transmission fluid change
Discussion in '1st Gen. Tacomas (1995-2004)' started by Metalman1, Dec 13, 2022.
  1. Dec 16, 2022 at 9:51 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    If you can, contact the seller and ask when the transmission was serviced. If this were my truck, I would replace the ATF filter and clean out the pan. If all you find is a mushy black substance on the magnets, I would feel comfortable doing a flush or drain/refill. If you find metallic particles or pieces of clutch material, just do a drain/refill.
  2. Dec 16, 2022 at 10:12 PM
    Caslon
    Caslon Well-Known Member
    2003 Base Cab. 2 whl drive. 5 speed
    Isn’t a flush just asking for it? I only had bits of metal on the magnet. You probably talking early 1st generation and lots of miles (needing a flush, grimy bad).
  3. Dec 16, 2022 at 10:24 PM
    Chuy
    Lakeside, CA
    Silver Taco
    @Caslon I admit I am not a trany mechanic. Relaying info from transmission mechanic recommendations. Members here have done flushes successfully on 200k+ Tacoma tranys. Generally, you will be OK as long as the pan is free of metallic debris. Some folks argue introducing fresh ATF fluid will dislodge matter ‘hidden’ in the transmission and clog up the valve body and other orifices. There is never any evidence provided. Mechanics do say to avoid using commercial flush machines that may be too powerful. Use the DIY method of using the truck’s ATF pump to flush out the fluid.
  4. Dec 18, 2022 at 11:37 AM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    Pretty sure my trans was never serviced over 200k until I bought it. Did a drain and fill x3 over 6 months and now the fluid has a good red color and shifts smoothly. Add a trans cooler as well - super simple takes an hour.
  5. Dec 19, 2022 at 2:51 AM
    Sfish2002
    Sfish2002 Well-Known Member
    Stanley
    2003 2wd M/T regular cab Tacoma
    Topper w/racks, bug/rock shield, hood thermal mat, bed liner, hitch
    I’ll venture a guess but it’s just that. As the ATF picks up particulates due to wear and the fluid just breaks down over time it gets more viscous. I bet the higher viscosity fluid tends to quiet things down because they’re “thicker” and don’t flow as well (think of Lucas oil additive here) so their interaction with everything in the AT is somewhat slower. I bet your truck had the whine when new and the ATF was pristine but because it increases viscosity slowly over time it was too subtle to notice until you changed it.
    Like you said though, I doubt anything is wrong.
    Just my $.02.
  6. Dec 19, 2022 at 5:37 PM
    Potomus Pete
    Potomus Pete Love my little truck
    Hippy
    Sarasota Florida The Great Place To Live.
    1999 Prerunner single cab. With a BO7A rear end
    All kinds 3 inch body lift/2 1/2 suspension lift. 31/11 1/2/15 tires All work done by myself for years. The only work performed by mechanic was fuel pumps. I also have a 90 Mustang 350 hp and I can never understand how come my Tacoma gets more respect Just got a 99 Jeep TJ that I rebuilt, and painted in the garage
    Just for the record I changed my fluid a couple times a year for fifteen years, and my auto trans wore out at 256K. I was very surprised because it was always totally clean
    GilbertOz likes this.
  7. Dec 19, 2022 at 5:40 PM
    shankyjones
    shankyjones Well-Known Member
    Richard
    Marina CA
    2003 Brown Tacoma Prerunner V6 3.4L TRD
    Potomus Pete - that can't be good. Did you drive it hard or for long or short distances?
  8. Dec 19, 2022 at 5:51 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Yeah if somehow you had a crsytle ball......and left that last before last change ....it would of maybe gone another 20K........
    ......then you could of added a fiction modifier and got another 10 or 15K out of it.........
    Up to that point the clean fluid was your friend...........
    So if done everything right....and tweeked til the end....it may of lasted just short of 300K.......
    Got to remember these trannys were for small/mid light trucks with 14in or 15in wheels.....not uncommon for those to go way beyond 400K on original tranny.....
    Scotty says always save your last fluid.......may buy you extra 10 or 20K.....
    ....gives you some extra shopping time.....
    I keep the oil almost cystal clear.....and the steering......
    might want to let the Atf ride a little longer.......maybe even saving it....for a while after changes....
    Big believer in Lubguard........however in real old trannys it may cause the seals to start to leak.........to counter that.....you need ATP AT-205......
    so wouldnt mix those two.........
