Transmission Fluid Change
Discussion in '1st Gen. Tacomas (1995-2004)' started by Sjb7w6, Mar 7, 2023.
  1. Mar 7, 2023 at 2:57 PM
    Sjb7w6
    Sjb7w6 [OP] Member
    Sam
    2001 4x4 v6 Manual
    Have a 2001 with 270k miles on it. I've only had it since 262k miles and am unsure of its fluid history. I'm draining and filling the differentials, transfer case and transmission.
    Is changing the trans fluid and transfer case at this point risky as far as knocking particulates loose and messing things up?
  2. Mar 7, 2023 at 3:06 PM
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    I think as long as you drain and fill you’re fine from what I’ve read. That’s what I did and I’ve been fine.
    ztwatson and Sjb7w6[OP] like this.
  3. Mar 7, 2023 at 3:11 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Drain, Fill, and Go:thumbsup:
    Don’t flush it.
  4. Mar 7, 2023 at 3:37 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Is your tag info correct, you have a manual? If so, you don't have the same issue as automatic transmission with the whole changing the fluid situation. Just make sure you're using the correct oil (everyone has a favorite, but IMO as long as it's new, you're fine) for a manual transmission, and not ATF. The rear diff, manual transmission, and xfer case are all going to be 24mm- get yourself a good 6 sided socket and a breaker bar to free them up.
    Be aware that the front diff has female hex drain and fill plugs, either 10mm or 12mm, I don't remember. So you need to get yourself a giant allen set. They are a pain to get to and open if they haven't been serviced before. Hit them with some pb blaster a few days before doing the work.
    Sjb7w6[OP] likes this.
  5. Mar 7, 2023 at 4:32 PM
    Sjb7w6
    Sjb7w6 [OP] Member
    Sam
    2001 4x4 v6 Manual
    Thanks for the detailed info!
  6. Mar 7, 2023 at 4:59 PM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    I did my manual transmission fluid change at 225,000 when i got it. Looked old. No issues with a drain and fill 13,000 miles later.
