Transmission fluid change.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cdex8357, Jul 15, 2023.
  1. Jul 15, 2023 at 9:04 AM
    cdex8357
    cdex8357 [OP] “Everybody gotta die sometime”
    “Dex”
    H-Town
    2013 Taco OR
    Mid travel FOX 2.5 Coilovers FOX 2.5 secondary bypass FOX 12” Triple Bypass
    I have a 2013 Toyota Tacoma with a AT. Dealership told me I had to do the fluid/flush at 80,000 miles on the transmission, seems a little late to change the fluid.
    I’m at 75000 right now, what do you guys to think..?
    should I have it flushed or just drain and fill it up ?
  2. Jul 15, 2023 at 9:15 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If it was mine I'd drop the pan, change the filter, clean tha magnets, fill it up, and run it, do that every 60k.
    b_r_o and BlkDakDave like this.
  3. Jul 15, 2023 at 9:26 AM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    Interesting the dealership said change it at 80k. Toyota AT is supposed to be "lifetime" fluid.
    I did my own drain and fill at 75k and then actually dropped the pan and changed the screen before refilling ay 150k. I'm coming up on 225k and will do another drain and fill.
    It isn't hard to do yourself if you look up the directions on TW. The pain is getting it in temp check mode, but if you're patient you can do it.
    I don't believe in the "lifetime" fluid deal and would do it between 75 and 100k depending on how hard you drive and if you tow anything. That's how I roll.
    cdex8357[OP] likes this.
  4. Jul 15, 2023 at 9:28 AM
    Bishop84
    Bishop84 Well-Known Member
    It's lifetime per environmental standards. If they advised an interval it would impact the footprint of the vehicle.
    We recommend 5 years 60k. I personally do every 30k but I'm higher mileage.
    cdex8357[OP] and Dm93 like this.
  5. Jul 15, 2023 at 9:31 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Pretty much all manufactueres these days say their transmissions have "lifetime" fluid, in reality they aren't wrong. It will last the life of the transmission, what they don't tell you is what that lifetime is or that it will probably last longer if you service it.
    TnShooter likes this.
  6. Jul 15, 2023 at 10:34 AM
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    Interesting they say lifetime..
    I know there are two ways to do this. One is where they hook it up to a machine and it flushed out all the old fluid and they pump in clean fluid.
    the other is what I can do in the garage. Where you basically drain it and fill it up.
    what is the better route?
  7. Jul 15, 2023 at 10:35 AM
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    The screen is the filter correct?
  8. Jul 15, 2023 at 10:41 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Flushed mine at 90k will flush every 60k going forward will never remove the pan unless it’s leaking.
  9. Jul 15, 2023 at 10:42 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    As @Bishop84 said it's more for EPA reasons and also so they can claim lower maintenance costs than anything else.
    It's up to you but I prefer to do a pan drop, you get about half the fluid changed but if you do it regularly it keeps the fluid fresh.
    If your transmission has any trash in it flushing (depending on the method they use) can stir it up and it can end up in the valves and solenoids causing issues.
  10. Jul 15, 2023 at 11:04 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  11. Jul 15, 2023 at 11:38 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    I do a drain+fill of 4qts every other year. Keeps the additive pack replenished.
  12. Jul 15, 2023 at 11:57 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    I did mine in the heat of the day. Keep the new fluid in the same environment as the truck. When I put the new fluid in my pan temp reading was 97 degrees. I didn’t have to warm it up. Opened the level plug and about half a qrt came out.
    You can also try measuring what comes out cold then refill the same amount. That should put you in same ball park.
  13. Jul 15, 2023 at 1:36 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    It's considered lifetime because it isn't economically smart to ever change it. We aren't living in the 1950's anymore but some guys just can't wrap their heads around that. You can change it every 30,000 miles if you want to, but the transmission won't last any longer than the guys who never change it. By the time you get to 300,000 miles you've paid more to have it serviced than it will cost to rebuild it.
    I've been driving 50 years, never changed transmission fluid in any vehicle. If the transmission goes bad in one of my vehicles today and has to be replaced, I'm way ahead financially.
  14. Jul 15, 2023 at 2:45 PM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    Yes
    cdex8357[QUOTED][OP] likes this.
  15. Jul 15, 2023 at 7:19 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Not trying to argue but I've seen you claim you can get a transmission rebuild for as little as $1,000 .. o_O
    A professionally rebuilt 4x4 transmission installed with a warranty is easily 4-6 grand these days. Not to mentioned the fact that by simply letting someone remove/replace the unit opens up the possibility for other damage along the way like stripped bolts, rusty exhaust parts that can break.. especially if you're shopping around for a cheap labor rate. There's no way a half dozen fluid exchanges is going to cost more than a reputable rebuild.
    Transmissions simply don't fail as much as they used to back in the 90s. I'll happily service the fluid if it increases the chances of never having to replace the trans..
  16. Jul 15, 2023 at 9:06 PM
    davep2012
    davep2012 Well-Known Member
    Dave
    2012 Silver Tacoma
    Weather Tech floor mats and Marathon Seat Covers
    I personally like to change ATF and get all of the friction material floating around out of the system. Between heat cycles and friction material, changing ATF is the only thing you can do to keep an automatic alive.
    b_r_o is spot on with his cost estimates. 15 years ago, an automatic transmission replacement for a Honda/Acura at the dealership I worked at was $5-$6k back then. To each his own.
    2015WhiteOR likes this.
  17. Jul 15, 2023 at 9:41 PM
    oldtimertoyota
    oldtimertoyota Well-Known Member
    New Mexico
    2009 4X4 Double Cab-1986 2wd Pickup Orig own
    It always interesting with the different ideas
