Transmission fluid change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Strand the berg, Oct 1, 2023.
  1. Oct 1, 2023 at 2:33 PM
    Strand the berg
    Strand the berg [OP] New Member
    Garrett
    2015 Toyota tacoma white
    My Tacoma has 114000 miles and bought it at 107000. Should I flush the transmission. Not sure if it’s ever been done before on it.
  2. Oct 1, 2023 at 2:42 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Start with a drain and fill. I’ve used Valvoline for the last few D&F’s. Valvoline MaxLife can be had for about 23 a gallon.
    Doc Samson and Geeves77 like this.
  3. Oct 1, 2023 at 2:45 PM
    Strand the berg
    Garrett
    Thanks! I feel like it’s not shifting properly from 3rd to 4th I feel just a little thud but I could just be overthinking it to much thinking the transmission is going out.
  4. Oct 1, 2023 at 10:56 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    These transmissions are pretty much bulletproof. A lot of tacomas have 200k-300k on the with no issues related to the transmission.
    Just do a drain and fill.
    The only issue that I know and had, I had the “shudder” when the transmission would shift into 5th gear at low rpm (below 2k)….i would get a vibration when giving it very small amount of throttle. A tube of “shudder fix” helped me.
    Doc Samson likes this.
  5. Oct 2, 2023 at 10:12 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Would absolutely not flush. If you'll sleep better at night drain and fill, a flush could do more harm than good. A drain/fill probably won't help anything, but probably won't hurt either.
    I don't service transmissions. After 50 years of driving, I've never had one go bad and I've never seen anything that proves changing the fluid makes them last longer. Unless someone abuses the transmission or lets the fluid overheat the factory fluid will usually outlast the rest of the truck.
    Blockhead likes this.
  6. Oct 2, 2023 at 10:45 AM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
  7. Oct 2, 2023 at 11:24 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If your truck has the towing package with the ATF cooler.
    You can pump more fluid out the coolant line hose. But it “takes more work”. (Not a lot).
    That said, a drain and fill would be good. Eventually you might drop the pan and clean the magnets and filter. Or not?
  8. Oct 2, 2023 at 11:27 AM
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
    You're definitely due. Mine started developing a shudder at 70k between 1000-1,500rpms going from second to third, and it was the ATF gone bad.
    Whatever marketing genius decided to tell toyota techs (who then parrot the following to customers) that the fluid "will last the life of the engine" deserved to be fired.
  9. Oct 2, 2023 at 11:37 AM
    MadRussian
    MadRussian Well-Known Member
    Metrowest MA
    2010 TRD OR AC
    I recently did a bunch of reading on this topic. My takeaway - every 60-80K drop the pan, clean the magnets and refill the ~4.5qt that you drained. I also recently changed the filter, but I don't think that was necessary.
    2015WhiteOR likes this.
  10. Oct 2, 2023 at 2:15 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I would do a drain and fill with OEM fluid, see how much better it works after a few hundred miles for the fresh fluid to work its way throughout. If you plan to keep the truck a long time, you can drop the pan and clean it out/replace the "filter" which is just a screen. Not necessary though. I did drain & fills at 60k and 90k, dropped the pan/new filter at 120k, then drain & fills at 150k and 180k. Still shifts great at 189k. Highly recommend using OEM fluid -- this service is not needed often and the OEM stuff is not that much more than the universal stuff. Good luck.
  11. Oct 3, 2023 at 3:00 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Thank you!
    I’ve been driving since 1978, never changed tranny fluid on any vehicle ever, and never had a tranny fail on any vehicle. I usually keep my vehicles for at least 200k miles, drive 45k plus per year.
    knottyrope likes this.
  12. Oct 9, 2023 at 9:53 AM
    Strand the berg
    Garrett
    Thanks for all the feed back y’all! I appreciate it and will let you know how everything goes.
