Transmission fluid change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hauser94, Jan 7, 2024.
  1. Jan 8, 2024 at 8:50 PM
    kmort
    kmort Member
    Kevin
    2020 Cement Tacoma TRD OR
    Stock ATM
    I did mine just yesterday with just under 60k on it. I’ve done mild towing with it over the last 3 years, so figured doing it early wouldn’t hurt. I feel a considerable difference in shifting quality since the change, so I’ll probably stick with the 60k or when I start feeling abnormalities
  2. Jan 8, 2024 at 9:08 PM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    I don’t believe they are the same, and the exchange will get more or all of the fluid changed.
    I had the dealer do it maybe a year or more ago, I think it was $450ish.
    Just looked at my notes and it was 550 done at 49k
    Either exchange or flush will do more fluid than a simple pan drop, in the end a pan drop is better than not doing anything.
  3. Jan 8, 2024 at 9:16 PM
    SmoothTRD
    SmoothTRD Well-Known Member
    Drain and fill every 60k, pan drop, filter change at 200k. I did it at 100k and it was complete overkill.
    230k trouble free miles so far
  4. Jan 8, 2024 at 9:57 PM
    chasecmc
    chasecmc Well-Known Member
    Chase
    2017 DCSB TRD OR
    GFC
    You are at low enough mileage a flush is probably going to be fine, but most people will caution NOT to do a full flush. Automatic transmissions actually rely on some of the clutch material that has worn off and is suspended in the fluid to not slip. Contrary to what some here are saying about a drain and fill not being good, I would say it is much better with an automatic transmission.
    lots of videos out there on the topic.
  5. Jan 9, 2024 at 2:50 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I had all my fluids changed out on my 2018 with 30k miles on the odometer. I also did a power steering flush, radiator flush, transfer case and diffs, new serpentine belt, plugs and filters just as a piece of mind.
  6. Jan 9, 2024 at 3:04 AM
    khax
    khax Well-Known Member
    Kelley
    2018 Tacoma TRD Off Road 6MT
    I started out this way but came to the realization that the maintenance will add up to a new truck before I ever touch 200k. I've been trying to decipher this service manual for weeks
  7. Jan 9, 2024 at 3:06 AM
    khax
    Kelley
    Do you have an automatic transmission? I just hit 60k in the MT.. Seems easy enough to do, but the truck is running great and it feels dumb to spend money on something I might mess up for no reason. But it feels even dumber to pay twice as much for the stoner kid at the dealer to do it..
    GoldenTaco27 likes this.
  8. Jan 9, 2024 at 3:10 AM
    VaToy
    Parts Unknown
    I did it because it was coming up in 6 years. Three plugs were sightly loose and looked okay but had them changed out as well. Been a few weeks and my mpg have improved slightly.
    khax[QUOTED] likes this.
  9. Jan 9, 2024 at 6:22 AM
    kmort
    kmort Member
    Kevin
    Stock ATM
    I have an automatic. I went back and forth on whether I wanted to do it or not, but since I do all of my maintenance myself I figured I’d just do it at the same time as my front/rear diff, oil change, and transfer case change. It is tedious since you have to wait for the trans to heat up to a certain temp for the level check, but you can’t really screw it up
  10. Jan 9, 2024 at 7:07 AM
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    Have a Taco and a RAV4 in the family. Taco is under 10K, so it will be a while.
    My personal preference is no more than 40K for ATF, especially if vehicle tows or carries heavy loads (as in my family Chrysler minivan, loaded with the whole family and luggage).
    RAV4 ATF was replaced by Yota dealer at 75K (as soon as RAV married into the family, with my wife). RAV is used for short trips, does not carry heavy loads.
    I took it to dealer again at 112K miles (after scheduling and confirming my mileage over the phone). Thornton Road Toyota (Georgia, have not used them before for ATF service) refused to work on RAV ("high' mileage being their excuse) after I pulled into the drop-off bay. Wasted 3 hours of my time driving there and back.
    My mechanic put 12 quarts of ATF fluid thru the transmission, until fresh fluid started to come out. He said old fluid was black (not burned). So it will be going on a 35K miles schedule now, which means every 6 years.
    Transmission did not have any problems before, but it is smoother now.
    I am taking my Taco in at 40K to have ATF serviced. If dealer refuses, my mechanic will do it.
    Lifetime, or 100K is for the people who like to replace their transmissions, along with the fluid.
  11. Jan 9, 2024 at 10:41 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    IMO, no. flush old fluid goes out as new fluid goes in. exchange you add 3 quarts 3 times but the new fluid will mix in with the old. at best i would add 3 quarts and drive it for about 10 minutes hoping the all the new fluid gets into the tranny then drain and add 3 more quarts and drive 10 minutes and then add the last 3 quarts. having said that i don't know how long it actually takes for the tranny to suck up all the new fluid, i am just guessing. you don't want the new fluid mixing with the remaining old fluid.
    Hauser94[QUOTED][OP] likes this.
  12. Jan 9, 2024 at 1:35 PM
    Hauser94
    Hauser94 [OP] Well-Known Member
    2016 Black Tacoma SR5 DCSB
    Got it so fluid exchange is best practice if you dont want to flush
    Barsoom likes this.
  13. Jan 9, 2024 at 2:11 PM
    BMH
    BMH Well-Known Member
    Bruce
    Pend Oreille County, WA.
    2020 4x4 SR AC 2.7 liter - Bare Bones Base Model
    I'm with ya on that.
    I live by the creed of 'I've never seen anyone regret doing too much maintenance, but quite a few who regret not doing enough'...
    I do the oil/filter changes at 5-6K miles, and having just turned 50K had the drain-n-fill on the tranny... With a scheduled coolant system flush and refill along with gear oil change on both differentials and TC case coming in a week. I want my truck to outlast me.. LOL
    Barsoom likes this.
  14. Jan 9, 2024 at 4:44 PM
    BMH
    Bruce
    Yup... THAT.
    joba27n and chasecmc[QUOTED] like this.
  15. Jan 9, 2024 at 4:59 PM
    #35
    4runnerToTacoma
    4runnerToTacoma Well-Known Member
    22 SR5 V6 Taco, 03 SR5 V6 4runner
    Pretty sure its around 100K yes, beside if its worn out you will start hearing noise at high speeds.
  16. Jan 9, 2024 at 7:44 PM
    #36
    kahanabob
    Maui
    16 TRD 2WD 4DR
    Yes
  17. Jan 9, 2024 at 7:54 PM
    #37
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    What he’s describing is multiple drain and fills, which definitely contaminates the new fluid with old.
    “Flush” is the wrong word. With a fluid exchange the transmissions own pump pushes out the old fluid and fresh fluid goes in to replace it. I do it every 100 000 km.
    Barsoom and Hauser94[QUOTED][OP] like this.
  18. Jan 9, 2024 at 8:14 PM
    #38
    chasecmc
    Chase
    2017 DCSB TRD OR
    GFC
    I’d recommend the OP and anyone else do some research (ahem, 6:50 into the link) on the suggestions you are getting. People might get upsold on a flush because it makes a shop more money, but again.. I wouldn’t do it. Drain and fill.
    jerrybear likes this.
  19. Jan 9, 2024 at 8:59 PM
    #39
    Hauser94
    So my next question is is that something the dealership will do? Or will i sound crazy asking for a fluid exchange. Or will they be like it’s either a drain and fill or a flush
  20. Jan 9, 2024 at 9:05 PM
    #40
    TacoTuesday1
    FL
    no
    Barsoom likes this.
