Transmission fluid change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hauser94, Jan 7, 2024.
  1. May 27, 2024 at 7:35 AM
    #101
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    :sorry:..I mistyped that…it was 1/2 quart low
    Shades_Of_Red[QUOTED] likes this.
  2. May 27, 2024 at 8:25 AM
    #102
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    I’m glad I get to do my drain and fills every 20-30k from the start and call it a day. Every used truck I had to do the coolant line exchange method pumping 2-3 QTs in/out at a time to get it all out. It was a lot easier than doing 4 drain and fills in a row. I will try the Lubegard as well.
  3. May 27, 2024 at 9:39 AM
    #103
    crashnrondo
    crashnrondo Well-Known Member
    Ron
    Wisconsin
    2021 DCSB Limited
    I'm at 60,000 miles and I just did three back to back spill/fills, used 7 quarts. I ran the truck for 2 minutes each time before draining again. Up to this point I just did the spill/fill every 20,000 and it was only around 2.5 quarts getting replaced. I never noticed any change in shifting before but this time it is noticeably smoother so I'm glad I went through the effort to change more fluid out this time.
  4. May 27, 2024 at 9:56 AM
    #104
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    What do you attribute the smoother shifting to?
    I'm assuming it wasn't low on fluid, since this wasn't your first fluid swap.?
  5. May 27, 2024 at 10:07 AM
    #105
    crashnrondo
    Ron
    Wisconsin
    2021 DCSB Limited
    No it wasn't low before, I've done the temp mode check each time but I was low for the first change. I'm guessing it's just the additional clean/new fluid over the usual spill/fill I've been doing. After the change I took my normal route to and from work to test it out, the shifts during moderate accelerating seemed smoother. Maybe that was just a placebo effect but the downshifts while coming to a stop are not as nearly as sharp as before.
  6. May 27, 2024 at 10:31 AM
    #106
    jmneill
    SE
    Yea, @ 60,000 miles, even if you'd never touched it, there shouldn't be any noticeable diminishment in shifting with original fluid.
    Unless, of course, there's some underlying issue with the transmission itself..
  7. May 27, 2024 at 10:32 AM
    #107
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    There is a such thing as too frequent ATF changes, btw. The system actually needs *some* grit/contamination for friction in order to function optimally
    usmc2msu likes this.
  8. May 27, 2024 at 10:44 AM
    #108
    jmneill
    SE
    ^^ 100%
    I've heard it from reliable sources that power braking the shit out of any new truck for four or five minutes as soon as it leaves the dealer is highly recommended.
    Helps get some of that grit and contamination into the system that would otherwise take many thousands of miles.
    faawrenchbndr likes this.
  9. May 27, 2024 at 10:57 AM
    #109
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
  10. May 27, 2024 at 11:02 AM
    #110
    3rd gen AC SR5 4x4
    Weird
  11. May 28, 2024 at 7:48 AM
    #111
    gearcruncher
    Canadain bumper technician
    Grit in the system ?
    The goal inside the transmission is to try and keep any grit on the bottom of the pan or on the magnets
    Hydraulic pressure squeezes the clutching together for the transmission to upshift to the next gear . The clutches and steels are smooth like a brake rotor and brake pad .
    Old spent transmission fluid loses it friction capabilities .The reagents in the old fluid have depleted . Takes longer for the clutch to squeeze together causing shock loading .
    When you service the transmission by adding some new fluid , you are restoring the friction modifiers in the fluid which in turn makes the transmission clutching squeeze smoother .
    Trying to explain what happens , so everyone understands at the basic level
  12. May 28, 2024 at 8:04 AM
    #112
    usmc2msu
    usmc2msu Well-Known Member
    TJ
    2017 SR5
    Is it clutch material that you want a bit of in there? Or is that a myth?
  13. May 28, 2024 at 8:19 AM
    #113
    gearcruncher
    Going to say its a myth .
    The clutches are super soaked in fluid during assembly . There is no grit on the clutches . The clutch steels are also very smooth .
    Have a look at the clutches on this 2016 6 speed transmission . 13 minutes into the video
    https://www.youtube.com/watch?v=Qs2P-uENGh0
  14. May 28, 2024 at 8:20 AM
    #114
    Gutt Pile
    Gutt Pile Well-Known Member
    2016 Blazing Blue TRD Offroad
    Had local independent self proclaimed Toyota shop w good reviews do mine at 85K a month ago (2016). Had my first experience of harsh enough downshift to shake my truck and lost ability to shift out of 1st gear until it warmed up. So I'm pretty sure they under filled it and who know what damage that did? Once up to temp it's fine and have not had any issues other than this the month since they filled it. Was a big temp drop overnight and I did not drive it for 3 days straight. fluid was def dirty on flush. They listed 16 quarts consumed which smells like overfill actually. Doesn't this only take around 11-11.5 quarts if running tow package?
  15. May 28, 2024 at 8:35 AM
    #115
    jmneill
    SE
    And just like that, there goes my grit pack sales I was just about to drop on the TW market.
    Now what am I gonna do with 30 pounds of ground up clutch packs...
    Thanks for nothing Scotty, you ugly bastard..
  16. May 28, 2024 at 8:44 AM
    #116
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    Professor friday
  17. May 28, 2024 at 8:41 PM
    #117
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I too did 3 drain and fills and use the same lube guard platinum made big difference. Transmission temp stable at 185°F hwy 60mph , rolling 315/75/16, and stock gearing empty work commute. I towed our overland trailer over the weekend from western Washington to eastern Washington. Tranny temp hit 207°F at its highest. I'm running amsoil for tranny fluid .
    The transmission service for just the fluid is a simple task . Before I went ahead and did it myself I had Toyota do it and they were charging me over $200 and I now do it roughly for $60 myself .
    Now recently yeah I bout 9 bottles of amsoil and the lube guard but the results were worth it .
  18. Mar 25, 2025 at 3:38 AM
    #118
    YE2KA
    YE2KA Well-Known Member
    JB
    19 Cement Grey Tacoma Offroad
    I've heard this as well but I've always heard if the fluid is over 100k to just leave it alone
  19. Mar 25, 2025 at 3:40 AM
    #119
    YE2KA
    JB
    Whats the purpose of the check procedure
  20. Mar 25, 2025 at 5:52 AM
    #120
    jmneill
    SE
    To insure a proper fill level.
    That is some Scotty Kilmer type horseshit.
    HondaGM, usmc2msu and skidooboy like this.
