Transmission fluid change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hauser94, Jan 7, 2024.
  1. Mar 25, 2025 at 5:53 AM
    #121
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    Puts the fluid temp in the correct range for accurate verification of fluid level. Ski
    HondaGM likes this.
  2. Apr 7, 2025 at 9:48 AM
    #122
    nikonNUT
    nikonNUT Well-Known Member
    Arkansas
    2023 Electric Lime TRD OR
    Morning guys,
    Planning on tackling a drain and fill in my 2023 this weekend and have a really dumb question. Truck currently has 34K on the clock so how many drain and fills would you perform? Going forward I am thinking I will do it every 15K aka every 3rd oil change. Am I within the window for a single drain and fill or would you do more? Just trying to come up with a plan for the weekend.
  3. Apr 7, 2025 at 10:10 AM
    #123
    crashnrondo
    crashnrondo Well-Known Member
    Ron
    Wisconsin
    2021 DCSB Limited
    At that mileage I'd just do 1 drain and fill, it'll be fine with your plan moving forward.
    MGMDesertTaco and nikonNUT like this.
  4. Apr 7, 2025 at 10:12 AM
    #124
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Do a single drain a refill.
    There is no necessity to do frequently. Instead monitor tranny temps. If your driving yields temps above 200° On consistent basis, then switch to a frequent schedule
    nikonNUT[QUOTED] likes this.
  5. Apr 7, 2025 at 8:41 PM
    #125
    nikonNUT
    Arkansas
    Thanks, everyone! Just wanted to ask as it gets hot here. Think 30+ days over 100F and I have seen 114F and I never want to again with the humidy we have here. That said I just want to get the truck on "my" schedule and go from there. 3 quarts every 15k seems like cheap insurance. Hopefully it's as easy as the videos make it out to be!
    xBloodxLinex likes this.
  6. Apr 7, 2025 at 8:50 PM
    #126
    Vlady
    Issy, WA
    Just pick a number and go for. You will come to senses when you do the next drain.
  7. Apr 7, 2025 at 9:02 PM
    #127
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    I do a drain and fill every 30k or if i end up cooking the fluid over 212F
    nikonNUT likes this.
  8. Apr 12, 2025 at 1:46 PM
    #128
    nikonNUT
    Arkansas
    Well, the drain and fill went off without a hitch! Well... One hitch. That heat shield is apprently made of recycled razor blades! Anywho... Did a drain and only got 1.9 quarts out so I filled it up, got the level correct, and took it for a drive. Much better! Did a second with a bottle of Lubeguard Platinum just because and will get it on a maintaince schedule now. Very happy with the results and I'm glad I checked when I did. Not burnt but lacking that pungent transmission fluid smell.
    RustyGreen and Canadian Caber like this.
  9. Apr 22, 2025 at 11:54 AM
    #129
    toficos
    toficos New Member
    2021 Tacoma TRD Sport 2WD
    Hey Guys! I have almost 85k on my 2021 taco trd sport v6. I've been taking it to the dealership for its services since its birth for its basic health. They recommended a Brake Fluid Change($386.65) & a Transmission Drain & Fill ($436.62). That seems insane to me. An independent Toyota Service Shop told me $170 for the Brake Fluid Change, so I'm probably just gonna go there... or do it myself following Team Oil Drop's vids. What do you guys think about the drain & fill though? The independent t shop told me they don't do them, read the owner's manual and that its sealed but idk man I'm seeing conflicting opinions.
  10. Apr 22, 2025 at 12:31 PM
    #130
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    You can take it one setp further!
    @Soft Taco has a new video out with the filter replacement found here. Another old skool video by Justin found here :thumbsup:
  11. Apr 22, 2025 at 6:38 PM
    #131
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Some say to never touch it.
    Some say to only drain and fill. Especially if it's never been done ever.
    Some say to always do a complete flush and refill. Also, drop pan and change filter.
    Same say to do a complete flush and refill once in the beginning, then only drain and fill after.
    Some say to only do a drain and fill at 100K and then 50K after.
    CCN says to only drain and fill. Only flush + fill, plus and maybe drop pan and change filter as a last resort.
    He says the fibrous material from the clutches floating around are good to keep in there.
    Personally I think I will do just drain and fills. Once at 100K and then at 50K there after. I'm looking at, dare I say a trusted dealership at this point. I don't have the space or resources.
    YMMV..... Especially if you tow.
    https://youtu.be/TevK-u3vkx4?si=RKKImGA4OwpHGwAA
  12. Apr 22, 2025 at 7:02 PM
    #132
    InThePlains
    InThePlains Well-Known Member
    My Tacoma is manual but I did a drain/fill ATF on my wife's 2nd gen Sequoia. This is the way I filled it from the top, really cheap and simple. See the funnel set up from 4:00 mark
  13. Apr 22, 2025 at 7:18 PM
    #133
    Vlady
    Issy, WA
    Are you comfortable DIY it?
    Fluid, washer, tools and rudimental obd2 will be close to $100 or more. If you follow Toyota guidelines, you would need a scanner with active test. It can be expensive.
  14. May 22, 2025 at 10:12 AM
    #134
    GawainXR
    GawainXR Well-Known Member
    William
    2020 TRD Off-Road
    DashCam
    Is there a published service life/change interval for the transmission filter? (Valve Body Oil Strainer Assembly)
  15. May 22, 2025 at 10:26 AM
    #135
    GawainXR
    William
    2020 TRD Off-Road
    DashCam
    Additional question: the Factory Manual specifies 3.1 liters/2.7qts when doing a drain and full but only 2.4 liters/2.5qts when the oil pan sub assembly is removed. Shouldn't that number when the pan is removed be higher then drain and fill since the drain plug isn't at the bottom of the pan?
  16. May 25, 2025 at 1:53 PM
    #136
    tacoma warrior
    tacoma warrior Well-Known Member
    2020 Tacoma SR5 silver
    My tacoma is a 2020 sr5 with towing package ,do I have to bypass the oil cooler thermostat? I have a otofix D1 Lite scanner.
    I connected the obd2 scanner and i was able to put the transmission on temp check mode, and yes i have to bypass the oil cooler thermostat.
