Transmission fluid change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Brooky816, Mar 20, 2025.
  1. Mar 20, 2025 at 3:37 PM
    Brooky816
    Brooky816 [OP] Well-Known Member
    06 Tacoma SR5 Prerunner double cab
    None
    Hey guys, I did 1 fluid change on transmission and she now shifts a little harder than before.It’s always kinda shifted a little hard from like 2nd and third and sometimes going down a hill but it’s a bit more now.I know it’s not gonna fail or anything but would you guys change fluid again and again or just keep rocking it?The fluid that came out was barely dark as she’s a
    Pavement princess with 90K. Thanks for any advise!
  2. Mar 20, 2025 at 3:50 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Just a SWAG, but I'd make sure you're not low on fluid. Personally, I'd have never touched it.
  3. Mar 20, 2025 at 3:51 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
  4. Mar 20, 2025 at 3:56 PM
    Brooky816
    None
    Yes, It’s not low.I did correct procedure.I did use valvoline max life fluid because many guys on here
    use it and not the Toyota fluid.I have no idea if that has anything to do with it but yes,I wish I had just
    left it along but too late now lol.
  5. Mar 20, 2025 at 3:56 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
  6. Mar 20, 2025 at 3:59 PM
    Brooky816
    None
    Yes,I followed a tread on here following procedure putting it in check temp mode and all but no I did not
    drop pan and change filter.Old fluid looked pretty clean and I wish I had not fooled with it.
  7. Mar 20, 2025 at 4:01 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
  8. Mar 20, 2025 at 4:01 PM
    Brooky816
    None
    Yes, buy the way thanks to the guy that posted that! It was a great procedure.
    winkel likes this.
  9. Mar 20, 2025 at 7:27 PM
    wdunnlee
    wdunnlee Well-Known Member
    Will
    Tidewater VA
    2010 Timberland Mica 4x4
    When I did a drain and refill I was advised to drop the pan and backwash the screen filter, clean out the magnets and pan. Don’t quote me in this but I believe there was something like if you drain it without cleaning or changing the filter it can clog the filter because all the shavings flow through it at once and then sit there.
    I believe it was on tacomaworld I was told that. Just an idea.
  10. Mar 20, 2025 at 8:46 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Hard shifts are not necessarily a bad thing (assuming the trans is OK).
    Hard shifts actually create less heat/friction and would technically be better for transmission life.
  11. Mar 20, 2025 at 8:55 PM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    I've done two complete 12 qt fluid replacements using Valvoline MaxLife. One at 90k and another at 160k. I too never dropped the pan. The transmission has always worked fine. No issues. It does have a firm, positive shift but I always thought of that as a positive. No mushy shifts. It's been many years but I don't remember it being very much different with the stock fluid. Maybe a little less firm?
    Also, I'm thinking I had a recall done years ago where they replaced or modified the gas pedal and also did a computer flash. I think the flash made the transmission shift a little better.
