Transmission fluid check??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dads truck, Jul 1, 2018.
  1. Jul 1, 2018 at 8:29 AM
    Dads truck
    Dads truck [OP] Active Member
    Stephen
    Uniontown Pa
    White 07 Tacoma
    5F483DBD-1211-4237-AD29-86CDF6D8D1DA.jpg ok, so I just got this truck from my father when he passed away. I just changed the oil and filter and checking all the other fluids. There’s no no transmission dip stick. None of the YouTube videos show my engine. Can someone please help me? I feel like an idiot, but I’ve never had a vehicle without a transmission dip stick.
  2. Jul 1, 2018 at 8:30 AM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Your truck doesn't have a transmission dip stick. It's supposed to be a sealed unit.
    WSW3 likes this.
  3. Jul 1, 2018 at 8:32 AM
    hoarder23
    Shay
    NJ
    Scratches
  4. Jul 1, 2018 at 8:33 AM
    Bishop84
    Bishop84 Well-Known Member
    Most modern vehicles no longer have dip sticks, the Tacoma requires a transmission temp monitor and you to open a spill check plug on the pan (5mm hex allen)
    If its not leaking its probably fine.
  5. Jul 1, 2018 at 9:29 AM
    Dads truck
    Stephen
    Uniontown Pa
    White 07 Tacoma
    It’s just had a little bit of a rough shift lately so I just figured I’d check the level. But if it’s sealed and the level doesn’t go down from leaking or burning, it should be fine. It’s a little worse with the ac on.
  6. Jul 1, 2018 at 9:38 AM
    CouchlessPotato
    CouchlessPotato Handcuffed to steering wheels still won firefights
    Zach
    You don't buy a truck for its fucking fenders!
    2.5" lift w/35's
    To check the level, you are supposed to get the transmission to operating temperature and remove the drain plug with the engine running. You should see a slow drip of oil if its full. You should probably change the trans oil every 50k miles or so. Old oil breaks down and the viscosity changes. You transmission might shift smoother if you change it, just make sure you fill it to the right amount or you can damage the transmission.
  7. Jul 5, 2018 at 2:57 PM
    craigs1
    craigs1 Well-Known Member
    2007 4Runner Limited, 4.0L
    Remove the drain plug?? Guessing you were referring to the level indicator plug, the one w/ the small hex bit.
  8. Jul 5, 2018 at 3:30 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    desertrunner24 likes this.
  9. Jul 6, 2018 at 8:37 AM
    CouchlessPotato
    Zach
    2.5" lift w/35's
    I'd have to look under there again, I changed my transmission fluid about a year ago, but you're probably right about the other plug. I just remember it was a plug on the bottom of the transmission and if the engine is off it will drain your fluid.
