Transmission fluid drained (sad face)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Macoman, Oct 30, 2018.
  1. Oct 30, 2018 at 8:29 PM
    Macoman
    Macoman [OP] Member
    2017 Silver Tacoma Sport 4x4
    Basically i went to change my oil and ended up draining the transmission fluid instead. So what i need to know is how much fluid would've been drained just from the plug alone and does the automatic transmission fluid brand matter? Thanks in advance!
    solgardener likes this.
  2. Oct 30, 2018 at 8:33 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    ~ 3 quarts. Use another vehicle and get 4 quarts of Toyota WS ATF fluid (as thats whats currently in the trans and i dont typically recommend mixing fluids) You will have to go through the fill level procedure.
    All that stated, i really dont get how people mistake the trans drain plug for the engine.... the trans drain plug isnt even UNDER the motor, like not even close by 2 ft!
  3. Oct 30, 2018 at 8:39 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Might be good if you got the Mod's to move this to the third gen thread or it could get confusing since it looks like your rig is a '17. Just sayin'
    PzTank and Macoman[QUOTED][OP] like this.
  4. Oct 30, 2018 at 8:41 PM
    nd4spdbh
    SoCal
    well.... he did miss the engine drainplug by a mile.... so posting in the wrong section goes hand in hand :D hahaha
    That stated, fill and check procedure on the 3rd gens if im not mistaken is very similar and should need about the same amount of fluid.
  5. Oct 30, 2018 at 8:43 PM
    FastEddy59
    Eddie
    Don't look for the dipstick :fistbump:
    PackCon likes this.
  6. Oct 30, 2018 at 8:44 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Not the first. Wont be the last. As stated above. Get proper Toyota fluid, fill, then follow the check procedure.
  7. Oct 30, 2018 at 8:47 PM
    nd4spdbh
    SoCal
    HAHAHA
    OP just dont be like the guy that did this exact thing (drain trans instead of engine).... then proceed to fill the radiator with ATF "because it had pink fluid".... i think he also double filled the engine as well.
    desertrunner24 likes this.
  8. Oct 31, 2018 at 3:57 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    In my opinion this is an easy mistake to make. Lots of people have done this, I’m honestly surprised it doesn’t happen more often.
    OP, you prolly won’t make this mistake again, but maybe think about getting a Fumoto valve so you’ll be able to drain oil with no tools.
    23Skidoo likes this.
  9. Oct 31, 2018 at 4:09 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Avoid driving the truck until you get the transmission fluid level straight.
    TheDevilYouLove likes this.
  10. Oct 31, 2018 at 4:12 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I've got that t shirt! Welcome to the club.
    Skierrichy likes this.
  11. Oct 31, 2018 at 4:51 AM
    solgardener
    solgardener Well-Known Member
    William
    '14 Tacoma DCLB SR5
    I did the same thing last week.
    ETA: edited because yours is 3rd gen. You're SOL now. Might as well trade for a Heep.
  12. Oct 31, 2018 at 5:18 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    This happens every few months to a member on here. Easy fix though other person!
    tcjacado likes this.
  13. Oct 31, 2018 at 5:21 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Might want to edit your link for a 2017 turd gen tacoma. Don't want OP not to verify the procedure is correct for his truck and beat his head over it.
  14. Oct 31, 2018 at 6:22 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Sad face indeed!
  15. Oct 31, 2018 at 8:54 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Dont feel bad,you are about the 100th guy that drained the tranny instead of the oil,
    Oil pan is =Black
    Transmission is =aluminum color
    Like I said many times,Toyota needs too put HUGE block letters stating oil or tranny fluid, on the oil pan and Transmission.Uh
    Skierrichy and Alexely999 like this.
  16. Oct 31, 2018 at 9:05 AM
    Thebubble
    Thebubble Well-Known Member
    Southern California
    2006 GX470
    2009 Pre-Runner, V6: Totaled 2014 Tacoma 4x4, 5 speed, 4 Cylinder: Totaled 2000 Tacoma 5 Lug: Sold 2006 Lexus GX470: Wheeling!!!!!!!!!!!!!!!!!!!!!!!
    sorry man.... but that is CLASSIC!!!
  17. Oct 31, 2018 at 9:37 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    But then people would know where the trans pan is and could service their non-servicable transmissions
  18. Nov 1, 2018 at 5:18 PM
    craigs1
    craigs1 Well-Known Member
    2007 4Runner Limited, 4.0L
    Nobody was born knowing which pan was the transmission vs. the engine. There are two ways to learn:
    RTFM, where you pay before you learn the lesson.
    School of hard knocks, where you pay after you learn the lesson. And it usually costs more time and $$.
    Take this experience as a teachable moment next time you pick up a wrench and head for your truck, make an informed decision.
    Alexely999 likes this.
  19. Nov 1, 2018 at 7:45 PM
    CBenfell
    CBenfell I don’t know sh*t about f*ck
    Christian
    Western Washington
    21 DCSB TRD OR Midnight Metallic Black
    Crippling Debt
    A truck least you drained your transmission from the intended drain location, unlike someone I know... :anonymous:
  20. Nov 1, 2018 at 9:02 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I have a dipstick in my 2012 transmission. :p
