Transmission fluid drained (sad face)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Macoman, Oct 30, 2018.
  1. Nov 1, 2018 at 9:09 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Every factory transmission pan that I have seen is painted black...
    Bebop likes this.
  2. Nov 1, 2018 at 9:41 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Good for you OP trying to do some maintenance yourself, learn from your mistakes. Get some red paint or nail polish and color in the transmission drain bolts to make them obvious not to remove.
  3. Nov 2, 2018 at 3:32 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    OP, the guys that bash you for this mistake have never, EVER, screwed up before. It would be nice to be them...
  4. Nov 2, 2018 at 4:30 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Fumoto valve and never have this problem again
    Thing is, I bet even if you brought your truck to any oil change place, this could happen too
    NAAC3TACO likes this.
  5. Nov 2, 2018 at 4:37 AM
    craigs1
    craigs1 Well-Known Member
    2007 4Runner Limited, 4.0L
    Or we did screw up, and got our chops busted and learned from it. :D
  6. Nov 2, 2018 at 7:19 AM
    96carboard
    96carboard Well-Known Member
    Careful there... "hand tight snug" has way too much room for interpretations.
    For instance, the factory oil filter on my snowmobile was done up "hand tight snug" -- either by an out of work sumo wrestler, or possibly the incredible hulk.
  7. Nov 2, 2018 at 11:05 AM
    96carboard
    No. That is definitely not the case. It was systemic. Every single unit sold that year had way over tightened oil filter. Reality is that they were probably torqued to spec, but the spec was off by x10.
  8. Nov 2, 2018 at 11:45 AM
    96carboard
    More likely just because it was first year for the model, and it was very radically different than anything the market had *ever* seen.... RX1. Not really the kind of new model entry you want to risk on the aptitude of the new guy. There was another spot I recall where a torque spec was off on it. Not from factory, but as printed in the service manual. They had the clutch bolt torque spec to something like 130 footpounds -- well you couldn't ever get it over 110, because the bolt would stretch. But that's the kind of weird crap that happens on such a radically new model.
  9. Nov 3, 2018 at 6:11 PM
    96carboard
    In so far as I'm an owner of one, sure.
    But no, I definitely had nothing to do with designing the machine, if that's what you're asking.
