Transmission Fluid Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Blumpkinson, Sep 18, 2009.
  1. Sep 18, 2009 at 6:12 PM
    Blumpkinson
    Blumpkinson [OP] Fuelled by plutonium and wild animals
    OR
    03 4x4 5spd
    Alright guys, its an 03 trd 4x4 5spd with right around 68,000 miles on it. I recently got the truck and have no knowledge of past maintenance. I was going to change the front are rear diff fluid this weekend and wanted to change the tranny fluid as well. I was wondering if changing the fluid could make the tranny slip, which would be a huge problem cause i'm tight on money right now:( and getting the tranny repaired is out of the question.
  2. Sep 18, 2009 at 7:05 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    with that low of miles.....you'll be fine. switching to a synthetic would be a pretty idea as well.
  3. Sep 18, 2009 at 7:23 PM
    Blumpkinson
    OR
    03 4x4 5spd
    Thx man, any specific brand you would recommend? Also, i am planning on taking it mudding every now and then, how often should i replace the diff fluid?
  4. Sep 18, 2009 at 7:32 PM
    Blumpkinson
    OR
    03 4x4 5spd
    yeah that and the grey wire mod are going to be tomorrow's projects after work.
  5. Sep 18, 2009 at 7:48 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    mobil1 75w90 will be good for the diffs,transfer case and your transmission.
  6. Sep 18, 2009 at 8:02 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Make sure to use the T-IV type tranny fluid if indeed your truck requires it.
  7. Sep 18, 2009 at 8:03 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    t-iv is for the auto. i think he has a 5 speed.:)
  8. Sep 18, 2009 at 8:05 PM
    humanoid
    humanoid bite me
    Sunny SoCal
  9. Sep 18, 2009 at 8:06 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    :D
  10. Sep 18, 2009 at 8:08 PM
    Blumpkinson
    OR
    03 4x4 5spd
    lol yup gotta love the manual
  11. Sep 18, 2009 at 8:19 PM
    98tacoma27
    Ben
    Not Beech Creek
    Make sure you get a GL-4 fluid and not a GL-5. They have been reports of GL-5 causing synchro issues in the first gens.
  12. Sep 18, 2009 at 8:37 PM
    Blumpkinson
    OR
    03 4x4 5spd
  13. Sep 18, 2009 at 8:48 PM
    98tacoma27
    Ben
    Not Beech Creek
    It's ok to use it in the diff's. I use Amsoil or Rotella. You can get the Rotella just about anywhere.
