Transmission Fluid Level
Discussion in '1st Gen. Tacomas (1995-2004)' started by smirk, Feb 24, 2020.
  1. Feb 24, 2020 at 6:49 PM
    smirk
    smirk [OP] Well-Known Member
    Hi Guys -
    I just had my transmission rebuilt about a month ago. The shop didn't tighten the drain plug enough, so I had a small leak going for a while. Once I realized this I tightened the plug up and checked the fluid - and it was way too high (or so I thought).
    So .. thinking the fluid was too high .. I drained some out via the radiator hoses. Now this is the moment where I actually researched how to properly check the tranny fluid level. I found an excellent thread on this forum, and realized that I was an idiot and I probably didn't need to drain any of the fluid because I wasn't checking it properly.
    After all that - I warmed the truck up, shifted it through all the gears once or twice, then checked the fluid - then added fluid back in until it was right where I needed it between the two 'hot' marks. This was about two weeks ago.
    I just got home from work today, and decided to check the level while the truck was still hot. Same procedure - shifted through all the gears, cleaned and re-dipped the stick, and now its too high again?!
    I think there is something I'm missing. Please advise?
    Thanks!
    :confused:
    Taco critter likes this.
  2. Feb 24, 2020 at 6:49 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
  3. Feb 24, 2020 at 7:28 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    How "high" on the dipstick tube?
    Could be you put in a little too much this time around. When you checked it the first time around, you did it incorrectly so you can't use that as a gauge to judge off of.
    Make sure you're on level ground when checking fluids and make sure the vehicle is on.
