Transmission fluid low???
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hektor, Jan 11, 2013.
  1. Jan 11, 2013 at 7:41 PM
    Hektor
    Hektor [OP] Well-Known Member
    Texas
    04 Tacoma 4x4 TRD DC v6
    I took my truck yesterday to the dealership to get a full transmission flush. The invoice states they used 12qtrs of T IV fluid. I feel my truck heavier!!! It shifts normal but I feel it heavier and also the transmission is noiser while acceleration. I checked the fluids today and at cold it show right in the middle. Now I let the truck running at idle for around 7 min and I read the dip stick it won't even get to the first line of hot. WTF is it missing fluid??? Did I check it correctly??
  2. Jan 11, 2013 at 7:48 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    You have to drive it around for the trans to warm up properly. And cycle through all the gears.
  3. Jan 11, 2013 at 7:52 PM
    bmpskir
    bmpskir Well-Known Member
    Dover, NH
    2010 TRD sport DCLB 4.0 auto
    typical process is drive for 10-15 miles to get the tranny up to temp, when you park at home shift down through each gear (leave it in gear for a long 5 count) then come back up doing the same... wait a few minutes then check the stick...
  4. Jan 11, 2013 at 7:59 PM
    Hektor
    Texas
    Sounds good would do it again tomorrow. Now if its a little low would it hurt to drive it for a couple of day till I take it back to the dealer?
  5. Jan 11, 2013 at 8:01 PM
    Hektor
    Texas
    Also does 12qtrs sound right to refilled??
  6. Jan 11, 2013 at 10:32 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    That sounds about right if you're including fluid in the converter too..
    Not a 100% sure tho'...
