Transmission fluid maintenance ATF
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gunmetal, Jul 24, 2013.
  1. Jul 24, 2013 at 9:23 AM
    Gunmetal
    Gunmetal [OP] Active Member
    Fairmont, WV
    08 TRD Sport Double Cab
    Mostly Stock, FX-R retrofit in progress, AFE pro dry S filter
    Bought my '08 v6 sport in 2010 with 47K on it. It has 78k now and I want to flush the transmission fluid. I want to do it myself and looking for some advice.
    Found a good "how to" thread, but I see people that swear by the OEM WS fluid and others say aftermarket compatible fluid is fine. Obviously, if i was to do a drain and fill the OE WS would be the smarter choice since that's what (i assume) is in there. But If you're trying to do a cooler line flush of ~12 quarts, is an aftermarket fluid fine to use?
    Also is a drain and fill recommended over this full drain? I know the pressure flush is never recommended.
  2. Jul 24, 2013 at 9:28 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    There are guys using Valvoline Max Life WS. They say they are not having any problems. I would think if you want to spend the money on the OEM fluid then do it, otherwise I would go with Maxlife.
  3. Jul 24, 2013 at 10:02 AM
    Gunmetal
    Fairmont, WV
    Cool, thanks. I want the best for my truck but don't want to fall for the manufacture's BS. I saw where some say Valvaline is better quality than OE. Any other brands or recommendations?
  4. Jul 24, 2013 at 10:06 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Those are the only 2 that I've seen people use and say good things about.
  5. Jul 24, 2013 at 10:11 AM
    Frogsauce
    Frogsauce Well-Known Member
    Chesapeake Bay
    16 TRD Offroad
    I used the OEM ATF. I read somewhere that it has additives in it that are required for certain Toyota vehicles (Tacoma is one).
    Not sure if that is true, but it's not too much more expensive for playing the safe side.
  6. Oct 23, 2013 at 11:14 PM
    arvizu9618
    arvizu9618 Well-Known Member
    RT
    PHX AZ
    06 D-Cab SPORT SB
    Map/Dome Light on same time, Beep onLock, Anytime DTRL's, Fog Light on any time, Cockpit lights in footwells, night light in cup holder and rear of console, Radio ON w/ ignition off (off with timer), 3157 socket for rear turn signals (BRIGHTER), Reverse Light Mod, Tap light in console and engine bay, removed screen prior to MAP sensor, Blacked out lower valance, badges, center caps and door handles, Added door sill plates, JVC-KDHDR50 Head unit (HD Baby), Tinted exterior lights, Borla Exhaust.
    Walmarts SuperTech says they are compatible with Toyota WS
    I used Valvoline's MaxLife at Vatozone, got it for $4.74 a quart when you buy 4 ;)
  7. Oct 23, 2013 at 11:38 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Did 3 drain n fills with the gallon jug of Valvoline Max Life fluid about 50k miles ago, no problems to report. Plan on dropping the pan and doing a full clean n flush when I reach 100k miles, which I have about 2500 miles to go for that.
