Transmission fluid mishap. Need help! Lol
Discussion in '2nd Gen. Tacomas (2005-2015)' started by alxdrmmr, Feb 11, 2017.
  1. Feb 11, 2017 at 6:38 PM
    alxdrmmr
    alxdrmmr [OP] TRD AZ
    alex
    Arizona
    2012 Tacoma TRD 4x4
    So my dumbass went to do my first oil change on the Tacoma.
    Not thinking straight I opened the overflow bolt on the transmission fluid tank. 1 quart drained out. (measured).
    Once my buddy came to help we bought 2 quarts and pumped it back through the fill in spot. After my buddy did some reading on here we decided to then again open the overflow on the trani tank and that's where it all ended.
    Is my truck drivable? Should I take it to get it checked out? How serious is the situation and what should my next step be.
    Thanks in advance!
    Ohh....... 2012 Tacoma 4.0 V6 4x4 Automatic.
    @theofficialtre likes this.
  2. Feb 11, 2017 at 6:41 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You might have too much fluid in there. I would take it to a shop and have a pro look at it.
    alxdrmmr[OP] likes this.
  3. Feb 11, 2017 at 6:44 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
  4. Feb 11, 2017 at 6:45 PM
    alxdrmmr
    alex
    Arizona
    2012 Tacoma TRD 4x4
    Sounds good!
    .... Any idea what they would do about it?
    Trani flush? Drain more fluid?
  5. Feb 11, 2017 at 6:45 PM
    MattScatt28
    MattScatt28 2017 Seattle Mariners AL West Champs!
    Snoqualmie
    What do you mean just drain it out? Haha
  6. Feb 12, 2017 at 4:52 AM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    If you drained one quart out, why did you guys put 2 quarts back in?
    Overflow on the tranny?.... that's where it all 'ended'?
    You're skipping a few steps in your explanation to us.
  7. Feb 12, 2017 at 5:22 AM
    pa blaster
    pa blaster Well-Known Member
    Scott
    central pa
    2024 GMC Canyon AT4X AEV
    :facepalm:I'm wondering why 2 quarts also :boom:
    File IFR likes this.
  8. Feb 12, 2017 at 5:27 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Me too
  9. Feb 12, 2017 at 5:35 AM
    jtv
    jtv Well-Known Member
    Well...Just Back From Hell
    2012 V6PreRunner TRDSport
    King all 4 corners, TRD cat back, OEM 17" TRD rims, Fold-A-Cover
    because he said "my dumbass" hahaha
  10. Feb 12, 2017 at 5:36 AM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    1) Start over.
    2) Put the right amount in there.
    3) You're done.
    :D
    tacomavoyager and File IFR like this.
  11. Feb 12, 2017 at 5:39 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Take it to a shop. Tell them the whole story. They will get a laugh at your expense, however they have the reader to get the fluid level correct.
  12. Feb 12, 2017 at 6:02 AM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
  13. Feb 12, 2017 at 6:13 AM
    devkurf
    devkurf Member at Large
    midwest
    Then spray some red or orange paint to mark the tranny pan when you get home. Mistakes happen, there are plenty here that have done the same thing. To quote your original post you are only a "dumbass" if it happens again. :)
    hogeyphenogey likes this.
  14. Feb 12, 2017 at 6:17 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Idle truck for 10 minutes, open fluid check port, let it drain until trickle. Close port. Done.
    Easy fix
  15. Feb 12, 2017 at 6:23 AM
    bajatacoguy
    bajatacoguy Well-Known Member
    Johnny
    RI to NH
    Blk Taco
    OEM: Bed Mat Roof Rack Tri-Fold Tonneau Cover Door Sill Protectors KO2's Dobinson GTS Suspension TRD Beadlocks Timbren Bump Stops SPC UCA Rear SuperSpring SSO Slimline Winch Bumper SmittyBilt x20 Mobtown Sliders Mobtown Front Skid Avid Basket Bed Rack DECKED Draw Organizer Total Chaos Bed Stiffners Relentless Fab Bed Corner Tie Downs CBI Ditch Light Brackets ARB Dual Compressor Instant Air Tank Smittybilt RTT Road Shower II Indel-B Fridge/Freezer w/ Slide Ironman 4x4 Insulated Fridge Case Redline Tuning Hood QuickLIFT Yo_Hec - Center Console Molle Little Johnny III CB Radio KB Voodoo Flashlight Kit Switch Pro 8100 BlueSea Fuse Pelfreybilt Fuse Panel Mount Gecko - LED Bed Lights Gecko - LED Hood Lights Raptor Grill Lights Cali Raised - Bed Flag Pole Holder Center Console Tray & Organizer Weather Tech Floor Mats Weather Tech Hood Deflector TRAILER BUILD HAPPENING! Plate: Negan
  16. Feb 12, 2017 at 6:37 AM
    devkurf
    midwest
    This would be fine, but when he says "thats where it all ended" it seems like there is some crucial information missing from the OP.
  17. Feb 12, 2017 at 6:48 AM
    nm4553
    nm4553 You had me at "Meat Tornado"
    Nick
    NEPA
    2017 DCSB TRD Sport
    SCS Stealth 6 Matte Bronze on Toyo Open Country 265/70R17, Fox 2.5 Coilovers, Bilstien 6150 w/ Remote Resi, Dakar Leaf Pack, Wheeler's Bumpstop, OVTuned
    You need to check the fluid level by properly engaging the trans. temp check mode. Once in that mode you can pull the drain plug and let any extra drain out. There are write ups on how to do this properly.
  18. Feb 12, 2017 at 6:49 AM
    cliffyk
    Cliff
    Saint Augustine, FL
    I wondered that myself; "ended" as in ENDED.?
  19. Feb 12, 2017 at 7:29 AM
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    OP - What fill port did you pump the fluid back into? You filled through the port on the top of the tranny, right? If that's what you did then like others have mentioned read over and follow the procedure for draining the fluid to the correct level. It takes a bit of patience but it's fairly easy to do. Just know where the exhaust pipes are when you're under there since the truck is running during the fluid level check procedure.
  20. Feb 12, 2017 at 7:53 AM
    alxdrmmr
    alex
    Arizona
    2012 Tacoma TRD 4x4
    "Ended" as in that's where we stopped. No fact is missing in the post.
    .....i Talked to a guy at Toyota last night and he's gonna take a look at it today.
    .... The truck is still under warranty and I think the worst is gonna happen I'm gonna have to get a tranny flush just so it's all the same fluid and they get get the right levels.
