Transmission fluid mistake
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacomaRoy, Sep 14, 2021.
  1. Sep 14, 2021 at 6:59 PM
    TacomaRoy
    TacomaRoy [OP] Well-Known Member
    Roy
    2021 Tacoma SR
    Hi, I made a mistake doing an all change today. Been working on mycars for 20 years, first time changing my oil on my Tacoma and I managed to drain the transmission fluid instead of oil. Still kicking myself 12 hours later. I measured 3.5 quarts came out. can I just replace 3.5 back in or do I need to go through the temperature checks running at both hot and cold as I've seen in a few YouTube videos? Thank you
    tacotoe likes this.
  2. Sep 14, 2021 at 7:03 PM
    Macsplace
    Macsplace Active Member
    21 Tacoma
    Do it correctly as the service manual states. How do you know it was actually full before? Dont mess around
    Knute likes this.
  3. Sep 14, 2021 at 7:06 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Just put 3.5qts new trans fluid back in
    AM6217, kahanabob, zoo truck and 2 others like this.
  4. Sep 14, 2021 at 7:07 PM
    dave5623
    dave5623 Well-Known Member
    2020 TRD Pro
    Don't you just fill until it dribbles out of the fill port? Assuming its on a level floor
  5. Sep 14, 2021 at 7:17 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Put it back in what you drained+some more(just a tip) . I heard 21's cannot be put in temp mode by jumping pins.
    May need to look for a help on a side or a dealer
  6. Sep 14, 2021 at 7:18 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    The fluids are always the proper level from the factory ! :crapstorm:
    pltommyo and TacoManOne like this.
  7. Sep 14, 2021 at 7:21 PM
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    can't you just drive the truck until the transmission reaches the correct temperature? btw, what is the correct temperature?
  8. Sep 14, 2021 at 7:24 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Fill at fill hole...
    Needs a dribble at the overflow hole when ATF temp is 95-113 degrees. There is also a drain hole...
    The hardest part, most of the uninitiated seem to complain about, is getting it into temp check mode. It's really not that difficult. I liken it to entering a cheat code on an old NES.
    Shellshock likes this.
  9. Sep 14, 2021 at 7:27 PM
    splitbolt
    NW Arkansas
    95-113F°
    There's only about a 5-10 minute window when the truck is at idle.
  10. Sep 14, 2021 at 7:30 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Just put back the 3.5 qts.
    If it ran fine before, you should be fine.
    I think you are probably overthinking this.
    Or, if it makes you feel better.
    Have a dealership check it. That way you know it’s right.
    AM6217 and shotgunbilly420 like this.
  11. Sep 14, 2021 at 7:36 PM
    Vlady
    Issy, WA
    the rumor is that 21s don't have an ability to jump pins on OBD connector, like previous years. So, you need a techstream or at least some sort of obd2 monitoring app to get a temperature.
    I'm sure a grill thermometer could work, but the issue is with maintaining a proper rpms for temp checking
    TacoManOne likes this.
  12. Sep 14, 2021 at 7:39 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    That sucks..
    Assuming the fill level was correct from the factory, adding the same exact amount as what came out should be good to go!
  13. Sep 14, 2021 at 7:45 PM
    Vlady
    Issy, WA
    For sure. Nothing is going to break. Just need to adjust a level..
    Need 24 mm socket with 6 conners (don't use 12) to get the fill plug out
  14. Sep 14, 2021 at 7:49 PM
    splitbolt
    NW Arkansas
    I thought 'they' figured that out...
    Basically the same procedure, sans the jumper.
  15. Sep 14, 2021 at 8:21 PM
    cryptolyme
    Virginia
    that's all i need. thanks.
    btw just heat it up to 120 and take your time.
  16. Sep 14, 2021 at 9:30 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    SR-71A and Smacky2020 like this.
  17. Sep 14, 2021 at 10:23 PM
    Jeffaz1
    Jeffaz1 Well-Known Member
    Phoenix, AZ
    2020 Tacoma TRD Pro MGM
    I did the same thing as you did several years ago on my 2006. I have heard of others doing this too. I didn't mess around though and just towed it to the dealer (was a free tow).
  18. Sep 14, 2021 at 10:37 PM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Manual FTW!! :kona:
    Too soon? ;)
    LunarRock_Pro, rtzx9r, OZ TRD and 4 others like this.
  19. Sep 14, 2021 at 11:43 PM
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    When its in the correct temperature range
    dave5623[QUOTED] likes this.
  20. Sep 14, 2021 at 11:53 PM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    95*~105*
