transmission fluid: put in 2.5 quarts, not filled yet?
Discussion in '1st Gen. Tacomas (1995-2004)' started by htuong95, Nov 13, 2010.
  1. Nov 13, 2010 at 6:07 PM
    htuong95
    htuong95 [OP] Have a nice day
    Sacramento
    2001 Tacoma 4x4
    Full OME suspension, Level 8 Tracker 16" wheels, BFG T/A KO 285/75/16, etc., work in progress...
    I have a 2001 4x4 v6. I just replaced my transmission fluid. The manual says I need 1.9 quarts. I put in about 2.5 and it does not over flow. Do I need to put in more? Just a little worried... Thanks in advance.
  2. Nov 13, 2010 at 10:24 PM
    2002quad
    2002quad Active Member
    Did you just drain and refill or did you replace your filter also?
  3. Nov 13, 2010 at 10:37 PM
    AvsFanTRD
    AvsFanTRD Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
    transmissions have filters?
  4. Nov 13, 2010 at 10:47 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    lol...screeeeeen...
  5. Nov 13, 2010 at 10:48 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Yes
  6. Nov 13, 2010 at 10:56 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Only Autos. The OP has a manual.
  7. Nov 13, 2010 at 11:06 PM
    htuong95
    Sacramento
    2001 Tacoma 4x4
    Yeah, I have a manual transmission.
  8. Nov 13, 2010 at 11:08 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    idk bout manuals but the autos is way off in the books as to how much fluid you need for a drain and refill
  9. Nov 14, 2010 at 11:12 PM
    2002quad
    Sorry I didn't see you had a manual, yeah my owners manual says I only needed 2.1 quarts, 6 later I'm where I should be......
