Transmission Fluid question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sbx22, Jul 20, 2010.
  1. Jul 20, 2010 at 7:09 PM
    sbx22
    sbx22 [OP] Member
    Norcal
    05 PreRunner DoubleCab LongBed
    Recently, went to my local Toyota dealer, and got a tranny flush. Here are the details. The service was $92, the flushing process itself was $29.99, and then it says 17@$6.80. I'm assuming that's 17 quarts of tranny fluid, automatic WS. Did I just get raped? This is my first time getting the tranny flush done.
  2. Jul 20, 2010 at 7:31 PM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    That sounds like a lot! Both in cost and quantity. Check your owner's manual, it should have the capacity in it, I doubt it's 17 quarts. Standard procedure for changing auto trans fluid is to let it drain and then fill it up with the same amount that drained. You never completely drain all of the fluid out of the trans, and this is the way it is typically done at certified shops too.
  3. Jul 20, 2010 at 7:37 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Your cooler, solenoids and torque converter all hold fluid. It doesn't return to the pan.
    When they flush, they remove the cooler lines and pump in and pump out an equal amount of fluid. It's not a change, it's a transfusion, since the new mixes with the old as it's pumped.
  4. Jul 20, 2010 at 8:32 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    As a reference, Firestone here does it for $140.
  5. Jul 20, 2010 at 8:37 PM
    larryde09
    Larry
    Rochester, NY
    This is one of those services that they rip you off all the time...it's not that hard to do yourself.
  6. Jul 20, 2010 at 8:39 PM
    Celtic
    Celtic Tactical Trunk Monkey
    Nick
    Willows, CA
    06 AC TRD 4X4 SR5 6spd
    BHLM, Devil horns, trimmed front flaps, Flowmaster muffler,
    It also depends on the type of fluid being used. Regular dextron/micrcon type III atf is cheap, while atf used on bmw, land rover transmission is about $14 a quart. So make sure you got a good price on fluid. They do call them stealerships for a reason... Don't heistate to make them explain what they did in detail. if they screwed up, check out the BAR, or Bureau of Automotive Repair. Dealer will change their tune quickly with the BAR on your side...
  7. Jul 20, 2010 at 10:14 PM
    sbx22
    sbx22 [OP] Member
    Norcal
    Well, I've been reading around here, and it seemed like the majority recommended the dealership to use their "computer" or "equipment" to do the flush. And yes, I'm aware, I probably could have done it myself. I wasn't willing to go with any other ATF besides the WS ATF. That's just me. Doesn't it suck that the V6's don't have a dipstick? This truck is starting to bug me. I'm a DIYer by heart, and I just felt so helpless taking it to the Stealership.
  8. Jul 20, 2010 at 11:32 PM
    Series1000
    Series1000 Gots a Taco!
    Vancouver Canada
    2007 Access Cab 4X4 4.0L
    3" Redi-lift (spacer lift) up front
    Hey man, around 12 liters is average for a clean tranny, if you drive hard or tow it may have been dirty - then its flush till its clean. big after market coolers add volume as well don't forget.
  9. Jul 21, 2010 at 12:12 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Does it really matter if you got raped - after the fact?
    You should've called the dealer to get a quote before having the service done and posted a thread about how much the quote was.
    For only $92 for a tranny flush? That's sounds cheap to me!!!
  10. Jul 21, 2010 at 1:09 AM
    Nirvana
    Nirvana Tesla Auto - Non union and proud
    Kris
    Bay Area, U.S.A
    2006 Off Road 4X4
    Icon ext. travel 2.5RR in front, Icon ext. travel 2.0RR in rear, BuiltRight uniball UCAs, Wheelers Superbumps, Goodridge steel braided brake lines, BruteForce front plate bumper w/ Warn M9000+synth line, 285/70R16 KM2s on painted stockers...because I'm not paying $800 to rock rash new wheels you scrubs. Shok Industries 2/0 big 4 upgrade and sound deadener.
    Yeah you got raped, just like I did when I took it in to get the trans fluid changed when I bought mine. It's just money, the world moves on.
  11. Jul 21, 2010 at 3:42 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    I think the tranny holds 11 qts... so they wasted 6 quarts @ $6.80. That's a lot of poor workmanship you're being asked to pay for.
    IMO, 3 qts should be more than a reasonable amount to see it running clear. You got it documented...do you suppose you could go back and get them to refund 1/2 of the waste?
  12. Jul 21, 2010 at 5:59 AM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    OP has an 2005. If he never change he tranny fluid I am sure it was dirty and a full flush would have reqiured more than 3qts. Just a drain and re-fill is ~3qts. Somebody did this themselves on here. I think it was 14qts he used IIRC.
  13. Jul 21, 2010 at 8:25 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    You missed my point...maybe I wasn't clear...
    I definitely agree 3 quarts isn't enough for a full flush...so...assuming the tranny holds 11 qts max, then their using 17 qts means 6 qts were wasted. Clumsy workmanship, inefficient / broken machine whatever it is THEIR fault, not the OP's.
    IMO, they should be able to flush to clear wasting no more than one quart...so giving them 3 is more than enough. Ask...no, expect them to refund the cost of at least three quarts
    In the good old days of $0.50 per quart I'd not care...but at $6.80 a quart it's a whole different story.
  14. Jul 21, 2010 at 7:37 PM
    sbx22
    sbx22 [OP] Member
    Norcal
    Chico, CA
  15. Jul 21, 2010 at 7:39 PM
    sbx22
    sbx22 [OP] Member
    Norcal
    No, do the math again... not just $92. In this economy, I want every cent worth it. I know I should have called the dealership and asked for a price, but whatever, it's all said and done with now.
  16. Jul 21, 2010 at 8:22 PM
    krans
    krans Well-Known Member
    Kenny
    Huntington beach/ West min duh
    09 Sport mall crawler
    Icon extended travel with resi front and rear,Camburg UCA, All pro standard leaf pack, Fogs anytime, General grabbers AT2,Custom stainless steel brake lines,bed box, Bestop soft top,50' light bar, amber rigid pods,CBI ditch mounts with LED pods,TRD intake,Anti dark hoodlights/rock light/LED whip,FX-R retros and Gibson catback..more mods to come
    What does the repair order say exactly? Just the 17@6.80? Maybe if possible scan the receipt or take a picture? I work at a dealership maybe i can help you out?
  17. Jul 22, 2010 at 3:26 AM
    tonto340
    tonto340 Well-Known Member
    Gambrills, MD
    Maybe the dealer drained and filled up twice. The requirement for my Acura TLS is to drain and refill 3 times which supposedly gets 98% of the dirty fluid.
  18. Jul 22, 2010 at 3:41 AM
    tacomarich
    tacomarich luvsoffroading
    rich
    arizona
    trd 4x4 offroad
    besides when it looks dirty, what is the amount of miles driven until toyota recommends changing out the trans fluid? i thought i read somewhere, 70k? anyone ever use lucas oil based transmission fluid?
  19. Jul 22, 2010 at 6:59 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    Most mfr's are just worried about getting cars to the 100K point with no major mechanical faults...most owners are happy with 36-60K. But there are a few who like to keep their's longer and know that more frequent auto tranny fluid changes have a major influence on service life.
    Many people do drain and fills (getting about 3 of the 11 qt. total capacity) at frequent intervals to at least keep the fluid fresh without the issues the OP had.
    I put in lucas auto tranny additive in my Maxima. The smell of the stuff tells me is prolly just ATF with a major dose of friction modifiers (amines, the smell is very distinctive) that made shifts a bit snappier; snappy shifts are good for clutch life but make the ladies fret when their double mocha capucino frizzies spill.
  20. Oct 13, 2010 at 3:30 PM
    FTB530
    FTB530 Well-Known Member
    Yuba City Ca.
    2005 toyota tacoma
    level kit,air raid intake,
    Well my locval dealer just told me it would cost me $435 to have my automatic tranny serviced,seems to me you got a great deal.
