Transmission Fluid Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacoboy69, Jul 10, 2018.
  1. Jul 10, 2018 at 9:00 PM
    tacoboy69
    tacoboy69 [OP] Well-Known Member
    ive seen posts about Tacoma’s coming from factory low on trans fluid. Will they ever check levels or replace as part of Toyota care? Or is it something I should bring up? Is this issue still present on 2018s? Shifting can be a little clunky at times, not sure if related or just normally how a truck shifts gears. I don’t really want to be that guy tho. Already had a few minor things looked at.
  2. Jul 10, 2018 at 9:03 PM
    magneticwhite88
    magneticwhite88 Well-Known Member
    Brandon
    OC, CA
    15' MGM Trd Off-Road
    I believe part of the regular Toyota care maintenance is to check all fluid levels, some dealerships will hassle you about it because it's more involved but they should do it.
  3. Jul 10, 2018 at 9:04 PM
    magneticwhite88
    Brandon
    OC, CA
    Be that guy, it's an expensive vehicle and you shouldn't have to worry
  4. Jul 10, 2018 at 9:58 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Absolutely check it out. Expensive vehicle? Hardly. Average cost for new all new vehicles in 2016 was almost $35K. We barely meet median man.
    daddy_o likes this.
  5. Jul 10, 2018 at 9:59 PM
    Rustytaco71
    Rustytaco71 Well-Known Member
    2018 4Runner
    Shoot me 36k please:D
  6. Jul 10, 2018 at 9:59 PM
    magneticwhite88
    Brandon
    OC, CA
    Okay Bill Gates
    Rustytaco71 likes this.
  7. Jul 10, 2018 at 11:43 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Look it up. Google is your friend lol.
  8. Jul 11, 2018 at 4:14 AM
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    Jan 2018 US sales
  9. Jul 11, 2018 at 4:25 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    My experience is a fluid level check is anything you can see with the hood open i.e., windshield washer, brake, power steering, and coolant. Good luck getting a dealer to check the transmission fluid level.
    over60 and 2016Tacoman like this.
  10. Jul 11, 2018 at 4:38 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Exactly. Just like checking differentials and transfer case fluid. Doesn't happen.
    over60 likes this.
  11. Jul 11, 2018 at 6:28 AM
    mbarbay
    mbarbay Well-Known Member
    Baton Rouge, LA
    2016 Tacoma BBP DCSB LTD 4X4
    The toyota care says to check all fluid levels. however, I had to put up quite the fight (making it all the way up to the owner of the 1st dealership) and in the end he still refused to do it for me. So i called the service managers of a different dealerships and told them that if they checked the fluid level for me, then I would be their new continued customer. Both of the other dealerships agreed to check my fluid level for me. and I have been using that dealership ever since with no complaints.
    So basically ask your dealership to. if they refuse, fight it. if they still refuse...find another dealer that will check it
    over60 likes this.
  12. Jul 11, 2018 at 6:38 AM
    tacoboy69
    For all of you that had it checked, did it end up being low?
  13. Jul 11, 2018 at 9:09 AM
    mbarbay
    Baton Rouge, LA
    mine was not
  14. Jul 11, 2018 at 11:05 AM
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
    Yes, it was 2 quarts low.
  15. Jul 11, 2018 at 12:45 PM
    TacoWil
    TacoWil Well-Known Member
    2018 Blue Tacoma TRD Pro
    I checked my 2018 with about 500 miles and it was fine.
  16. Jul 11, 2018 at 3:19 PM
    OregontoBajaCA
    OregontoBajaCA 2025 DC OR High Bread
    2025 OR DC iF Max
    Mine was just under 1 quart low when new. It was clunking when shifting from Park to Reverse and from Reverse to Drive.
    After adding 1 quart of fluid the clunking was gone.
  17. Jul 11, 2018 at 3:49 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Make sure you ask for the "physical" fluid check….NOT the computer one...for some reason, the computer check does not know how much tranny fluid there is in there..
    Oh, mine was 1 1/2 qts. low when I checked it myself.
  18. Jul 11, 2018 at 4:47 PM
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    No
