Transmission fluid recommendations
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PFD FIRE, Nov 3, 2022.
  1. Nov 4, 2022 at 8:17 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Toyota fluid is higher quality than aftermarket in this case. Oem fluid all the way
  2. Nov 5, 2022 at 1:45 AM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    Valvoline Maxlife or OEM.
  3. Nov 5, 2022 at 12:17 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Did a 12 qrt change with Maxlife. 80K I changed the pan to a deeper one and used Amsoil SS blue cap ATF. 40K since the change and all is good. Going to wait 30K to change it again. All is good with either.
  4. Nov 5, 2022 at 12:40 PM
    Sonofliberty92
    Sonofliberty92 T O Y O T A
    Mark
    Maryland 4 South
    2014 DCSB TRD OR, 2005 Tundra V8 4WD
    Only Toyota WS for me. It's what's designed for it and Toyota has an excellent reputation with long lasting vehicles. I trust this over any other brand.
  5. Nov 5, 2022 at 12:48 PM
    Sonofliberty92
    Mark
    Maryland 4 South
    Skip to 30:11
    Valvoline doesn't even have the licensing for the Toyota fluid or even Dexron/Mercon specifications. The Maxlife PI sheet says its NOT an OEM licensed product and not recommended by ANY OEM manufacturers.
    Toyota doesn't even claim WS compatibility with previous type 4 or earlier specs. I'm not trusting Valvoline over Toyota.
    https://youtu.be/xUFY0L_zFek
    Squirrel1969 likes this.
  6. Nov 5, 2022 at 2:02 PM
    saint277
    saint277 Vigilo Confido
    Don't think manufactures license any off brand fluid, and always recommend there own brand of fluids, you using Toyota brand diff, engine and Tcase oil to?
    Chuy and SR-71A like this.
  7. Nov 5, 2022 at 2:04 PM
    Sonofliberty92
    Mark
    Maryland 4 South
    It says doesn't have the license for the specifications. You left out one word. It would be dumb to think a manufacturer would license another brand. But they can however have the licensing for the specifications of the fluid.
    I actually did have them change my diffs but won't next time considering I had a locker installed. AT is a different animal than a differential or transfer case.
    Don't understand why it's so difficult to stay with the fluid that is made for it. You can get it at nearly the same price.
  8. Nov 5, 2022 at 2:11 PM
    saint277
    Price is not even close my man, you can get 4 quarts of maxlife for 25 bucks, your lucky to get ws for 10 bucks a quart. It more commonly closer to 12$ bucks a quart. If by "them" you mean the dealer there is 0% chance they put Toyota brand oil in your diff, they use whatever oil they can get in bulk the cheapest, they have no obligation to use Toyota brand fluids, if you need 75w85 (think 2015s need this spec) its most likely the wrong weight as well.
    SR-71A likes this.
  9. Nov 5, 2022 at 3:14 PM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    I'll stir the pot more.
    When I did a complete drain/flush per the procedure on TW, I used Valvoline Maxlife and with about 40,000 miles on it, I haven't had any issues.
    When I change my oil I use full synthetic versus conventional and change at about the 5000-mile mark. So far no issue.
    When I did drain and fills on my rear end, transfer case, and front diff. I used synthetic, even with the EGGS bearing installed. So far no issue.
    When I change my coolant, I did go with the manufactures recommendation, but with the auto store brand, not Toyota branded. So far no issues.
    When I bled the brakes on both the Tacoma and HHR I went with DOT 4 instead of DOT 3. So far about 7 years on the HHR and about 2 years on the Tacoma and no issues.
  10. Nov 5, 2022 at 5:02 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
  11. Nov 5, 2022 at 9:33 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I can understand why guys would want a dipstick.. but it doesn't need constant checking. If the trans is not leaking anything red, you're probably fine. Where else can the fluid go?
  12. Nov 6, 2022 at 8:18 AM
    saint277
    My truck has been fluid filmed, finding leaks based only on drips is tricky. Not really worried about the trans itself leaking, but I've had cooler lines fail in the past and they would be hard to spot in my Fluid filmed engine bay.
  13. Nov 6, 2022 at 9:45 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Yea, that’s the trade off. No good advice except check the levels periodically. I’m in the same boat.
  14. Nov 7, 2022 at 3:45 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Idemitsu is another good reputable manufacturer of WS. Made in Japan, I believe. And it comes in a 5-qt jug. Used it once but price has gone up, but more affordable than stealership. MaxLife has not let me down either. Wife’s old Lexus ES350, that we sold to daughter’s BF, has about 120K on two flushes of MaxLife.
    SR-71A likes this.
