Transmission Fluid Recommendations
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sabre170, Aug 19, 2025.
  1. Aug 19, 2025 at 5:53 AM
    sabre170
    sabre170 [OP] Well-Known Member
    Drew
    2016 Limited - 140k miles.
    I'm prepping to do a transmission fluid and filter change. I do know that in general, some vehicles can be very picky as to what brand transmission fluid is used and even more so, on cars like our old murano, anything other than the nissan brand fluid is a bad idea.
    What do yall use for transmission fluid?
  2. Aug 19, 2025 at 6:08 AM
    TailHook
    TailHook You just gotta keep livin' man, L-I-V-I-N
    Alan
    Southern UT
    2018 TRDOR 4X4, 2007 Sequoia 4X4
    Toyota WS
  3. Aug 19, 2025 at 6:27 AM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    Idemitsu Type TLS-LV.
  4. Aug 19, 2025 at 6:39 AM
    Big Cole
    Big Cole Well-Known Member
    Toyota WS. My local dealership had the best price available.
  5. Aug 19, 2025 at 7:08 AM
    sabre170
    Drew
    Awesome. Thanks. It looks like a fluid and filter change I should expect 3-4 quarts drained.....so I should probably add 5 qts and do the level procedure from there?
  6. Aug 19, 2025 at 7:30 AM
    Big Cole
    I did a drain and fill last week. Less than 2 quarts came out of the pan indicating underfill from the factory. Added 3.5 quarts and .5 quarts drained out during the temp check procedure. So basically net 3 quarts added
  7. Aug 19, 2025 at 9:27 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Here is the drain and fill video from the Maintenance Map thread.
    https://www.youtube.com/watch?v=rNqYpEpmUng
    GiveThanx118 and Chew like this.
  8. Aug 19, 2025 at 9:53 AM
    StZu
    StZu Where the White Women At?
    Richard
    Dallas Texas
    18 Super White TRD Offroad
    Level 8 Wheels, Bilstien/Eibach lift, 2" aal, blacked out rear bumper, AC drain hose relocation, sound deadening 4 doors and back wall, amp/speaker upgrade, 10" daytona sub, LED interior lights.
    tagged
  9. Aug 19, 2025 at 10:01 AM
    truckmike26
    truckmike26 New Member (2009)
    Toronto
    '21 DC TRD Off-Road, '94 Pickup (Hilux) V6/Auto 4WD
    MotoMaster Full Synthetic Multi-Vehicle LV ATF.
  10. Aug 20, 2025 at 3:03 PM
    lgram02
    lgram02 New Member
    Ravenol T-WS Lifetime
  11. Aug 20, 2025 at 3:27 PM
    sabre170
    Drew
    So I have to admit.....I saw a different video that showed that jumper trick to know when the transmission was at the right temp.....I figured it was a complete scam and I was going to have to sort a scanner to borrow.
    Love that I can do this without a computer!
    Related question: Filter: Was just planning on getting a filter off Rock Auto unless here are different suggestions on that.
  12. Aug 20, 2025 at 3:48 PM
    TA2016
    Oregon
    Post #8 has the strainer part number. I did a drain and fill like shown in the video and did not touch the strainer.
    https://www.tacomaworld.com/threads/2018-tacoma-transmission-filter-change.735795/
    sabre170[QUOTED][OP] and Chew like this.
