Transmission fluid temperature
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tmar04, Sep 4, 2024.
  1. Sep 4, 2024 at 4:05 PM
    Tmar04
    Tmar04 [OP] Well-Known Member
    Terry
    2004 Tacoma prerunner
    Does anyone have an idea what tranny temps should be on warm day, not towing with 2.7. Before cooler and after cooler(oem radiator cooler) trying to determine if mine normal
  2. Sep 4, 2024 at 4:38 PM
    Stuck in VT
    Stuck in VT Well-Known Member
    Utah
    2019 SR SX MGM
    Below 200f
  3. Sep 4, 2024 at 4:44 PM
    jpg366
    jpg366 Well-Known Member
    AL
    09 Silver Prerunner SR5
    Hitch, Running Boards
    It can’t get lower than coolant temperature.
  4. Sep 4, 2024 at 7:58 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Typically it will be the same as the coolant temperature under normal driving conditions. Under load it will start to climb. Above 200 is bad. Above 220 is really bad.
    Stuck in VT likes this.
  5. Sep 4, 2024 at 9:37 PM
    Stuck in VT
    Utah
    2019 SR SX MGM
    @jpg366 Maybe transmission cooler with tow package changes things. Rolling down the highway mine is 195-185 per scangauge. Never correlated that to engine temp.
  6. Sep 4, 2024 at 11:04 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    They can fluctuate quite a bit depending on load. So it is hard to say what "normal" is.
    In general I would agree with what is posted above. At highway speed with no climbing at all, typical will be the same as coolant temps in the same scenario. But can change quite a bit as a load is applied. Climbing a hill or going over a pass, 200-210° could be normal.
    Not always. It depends on how long those higher temps are maintained.
    This chart was posted recently in the daily thread that shows the trans fluid life expectancy at higher temps.
    https://www.tacomaworld.com/threads...t-gen-edition.138573/page-11103#post-30092550
  7. Sep 5, 2024 at 6:47 AM
    nzbrock
    Noah
    San Marcos, TX
    Maybe what I meant to say is the ideal temperature is under 200. Once you go above that the fluid will start to degrade faster. If it's only for a minute, it won't do much. If you expect to get 100k miles out of your fluid, then you need to keep it under 200. Even after I added a transmission cooler, I will still get temperatures above 200 in Texas summer in stop and go traffic. This just means I need to change my fluid more frequently than 100k miles.
  8. Sep 5, 2024 at 7:49 AM
    Glamisman
    Glamisman Well-Known Member
    The temperature measurement is dependant on where you measure it at. The highest temp will be at the output from the transmission, this is right off the torque convertor. What you are measuring in the pan is an aggregate measurement and if there is any damage to the fluid due to excessive temps, it has happened way before you can measure it.
    In modern transmissions this heated fluid is dumped back into the pan until the trans warms up, then the trans Tstat opens and send the fluid to the cooler, unless you own a Nissan, then it pumps it into the radiator coolant and visa versa, if you own a Nissan and have had a milksake tranny you know what I mean.
  9. Sep 5, 2024 at 8:56 AM
    Tmar04
    Terry
  10. Sep 5, 2024 at 10:27 AM
    Glamisman
  11. Sep 5, 2024 at 10:37 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    My 03' V6 auto uses the radiator to cool the transmission fluid as well.
    I added a separate transmission cooler so the transmission fluid goes >transmission>radiator>added cooler>transmission.
    I find my trans temps to be significantly cooler than before and when they do get hot they drop drastically as soon as the load is reduced like going from uphill to flat/downhill.
