transmission fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by currierstaco, Oct 21, 2012.
  1. Oct 21, 2012 at 11:18 AM
    currierstaco
    currierstaco [OP] Active Member
    Little Rock AFB
    05 sport pkg 3in lift on 20s and terra grappl
    spyder headlights, hids all around, painted bug deflector and window gaurds, 20s and terra grapplers, ready lift kit front, add a leaf rear, led tails and third, billet grille top and bottom, 2 polk audio mm1240dvc subs behind rear seat, hifonics 1000.1 amp, jvc deck, power acoustics 5 farad capacitor.
    I've got a 05 tacoma 4x4 v6 auto and I'm trying to change the fluid in the tranny. I've seen a lot of people say that you can only use toyotas WS fluid but i was wondering if i could use AMSOIL ATF and if it was safe to use or if it was gonna tear everything up inside it. Any help or knowledge would be helpful.
  2. Oct 21, 2012 at 3:16 PM
    jbrenn
    jbrenn Well-Known Member
    allen texas
    10 sr5
  3. Oct 21, 2012 at 3:54 PM
    zzchipster
    zzchipster Well-Known Member
    2013 taco 4x4 trd lwb trd sc
    trd s/c and exhaust, 5100's,bud builts
    i think i paid 135 for 13 qts w/tax of ws factory fluid.good for 60k miles...
  4. Oct 21, 2012 at 4:05 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    11 trd sport longbed
    weathertech visors,remote start,lojack, ARE z type topper, wet okole seat covers, pop n lock tailgate lock
    i think i would use the factory recommended fluids for the tranny
  5. Oct 21, 2012 at 5:17 PM
    currierstaco
    Little Rock AFB
    So y did you need so much fluid cuz my haines manual says i only need 3.2 even when i drop the pan so thats what i bought of AMSOIL was 4.
  6. Oct 21, 2012 at 6:01 PM
    jbrenn
    allen texas
    10 sr5
  7. Oct 21, 2012 at 7:20 PM
    currierstaco
    Little Rock AFB
    so if i pull the pan to clean out the filter ure saying im gonna need 13 qts?
  8. Oct 21, 2012 at 7:25 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    you don't pull the pan... you drain from different areas.
    Read the thread from the link he posted. Has complete directions.
  9. Oct 21, 2012 at 7:26 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2015 DC 4x4 base model
    Husky liners, Toyo Open country AT2
    Torque converter holds like 10, if u flush it, lines, cooler, the whole shebang, yes u will need at least that. Dropping pan doesn't flush whole system. You don't want to just drain pan and add a new fluid when there's lots of Toyota fluid left.
  10. Oct 21, 2012 at 7:30 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    And neither is a full fluid change needed as long as the drain/refill is done regularly.
  11. Oct 21, 2012 at 8:20 PM
    jbrenn
    allen texas
    10 sr5
    the v6 transmission does not have a filter. no need to remove the pan. just drain and fill about 4 quarts.
  12. Oct 21, 2012 at 9:42 PM
    currierstaco
    Little Rock AFB
    That blows that I just blew 60 bucks on AMSOIL ATF for no damn reason now. Appreciate the info though just saved me from mixing all that together.
  13. Oct 21, 2012 at 9:46 PM
    memphis guy
    memphis guy Well-Known Member
    Memphis
    PreRunner TRD Off-Road
    Michelin LTX M/S II 265/75-16 Tires (+1 sidewall height)
    Go ahead and buy some more Amsoil fluid and do the complete transmission flush, as detailed by member Mountain Lion.
    It's easy - I just did it a couple of weeks ago. Someone else just posted the link in an above post.
  14. Oct 22, 2012 at 5:03 AM
    currierstaco
    Little Rock AFB
    The post looks great and doesn't seem to be hard at all. Appreciate the info
