Transmission Fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by defdonny, Mar 27, 2023.
  1. Mar 27, 2023 at 8:26 AM
    defdonny
    defdonny [OP] Member
    Donny
    05 black Taco 4x4 v6 auto
    stock, FJ wheels
    Hi all ! I need some help . I’m confused . Ok I got a 2005 Taco with 198000 miles . It has a 4.0 and auto . It’s also a 4x4 .Had frame replaced in 2015 at 95000 miles . While in dealer I told them to replace anything needing replaced. They did a transmission fluid change. I went back at 175,000 for leaf spring warranty and they changed fluid again . Now as I’ve learned from reading here and talking to technicians ( I work for O’Reilly’s) I’m hearing I was never supposed to go into the trans . I’m upset the Toyota dealer didn’t bother to mention this as they should’ve known . Now I’m wondering if I’m gonna have to continue to replace it or if I should leave it alone . I’m stumped. I’m having no problems either . Thanks
  2. Mar 27, 2023 at 8:36 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I currently do annual drain & fill(s). I started this after 45k miles. There are many TW threads concerning transmission fluid. Some verge on religious. Pick a philosophy and go with it. I belong to the Valvoline MaxLife sect.
    cmoore, HondaGM, defdonny[OP] and 3 others like this.
  3. Mar 27, 2023 at 8:41 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    just because it doesnt have a dip stick doesnt mean you dont have to change it.
    Spec is every 60k miles oil change intervals on the auto trans. You could get away with 100k if the truck sees mostly easy unloaded driving on the highway. If I were you I would get 12 quarts of Toyota WS, and a filter, drop the pan, clean the magnets, replace the filter and do the proper procedure to replace all 10-11ish quarts of fluid.
  4. Mar 27, 2023 at 12:36 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I don’t know where you read that on this site, but it’s wrong.
    So are the technicians you’ve talked to.
    The next time you see them, you might politely inform them that the fluid is serviceable.
    I’d call the dealership and thank them.
    They did you a favor, they helped your transmission last longer.
  5. Mar 27, 2023 at 3:07 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    You have wrong information?
    60/100K change fluid
    HondaGM, defdonny[OP] and 2WD like this.
  6. Mar 27, 2023 at 4:26 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Your manual will say to do an ATF change every 60K for special operating conditions - off-roading, towing, commercial-use, etc… Toyota doesn't identify how often of those activities you engage in. I do every 60-70K on my Taco and 70-90K on my family’s other vehicles. Agree to drop the pan every other flush, or 60K to wipe the magnets clean and replace/clean the ATF filter.
    HondaGM, defdonny[OP] and Williston like this.
  7. Mar 27, 2023 at 5:41 PM
    Williston
    Williston Unknown Member
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a couple of non-OEM nods.M mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    You're fine: Don't listen to the techs: You are supposed to go into the transmission: i.e.: fluid changes... the dealer did the right thing. Follow the "severe service recommendation" and do it every 60-75,000 miles and it will outlast you. (and any future owners too ;)) It's an Aisin transmission: I put 300,000+ miles on three Volvo's I owned with Aisin transmissions in them (AW70). 75,000 mile fluid changes: No slipping, no leaking: no nothing. I did put an aux cooler on all of them because I towed a small tent camper. (same cooler swapped to new Volvo) The fluid never even looked dark. Look at it this way: my last fluid change at the dealer cost me: $249. A new transmission is probably going to slam and sink you to the tune of $5,000 p&l. $249 x 5 = $1,245. I currently have 125k on my truck:
    Cheap insurance :thumbsup:
    HondaGM, defdonny[OP] and nd4spdbh like this.
  8. Mar 27, 2023 at 7:31 PM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    I agree with this sentiment.
    I last dropped my pan to replace the filter and gasket, and do a full fluid change (~13 qts) at 83k. I plan to do it again at around 150k.
  9. Mar 27, 2023 at 8:52 PM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    If anyone tells you that the fluid lasts you a life time then they (1) don't know what they are doing or (2) they are scamming you.
    I'm currently doing a drain and fill every oil change until the fluid looks bright red. You can use the Toyota WS or the Valvoline Max Life. I prefer Valvoline Max Life because you can also use it in your power steering system.
  10. Mar 27, 2023 at 8:55 PM
    rtilton12
    rtilton12 Get gas and GO!
    Robert
    Texas
    2012 Toyota Tacoma TRD Off Road 4x4
    Trail gear front and rear bumper, RTT, hitch grill, 12k lb winch, drilled and slotted front brakes
    flushed mine one time at 50k miles and wont do it again. im at 124k miles now and no issues
    HondaGM and defdonny[OP] like this.
  11. Mar 28, 2023 at 5:23 AM
    Oldewing1800
    Oldewing1800 Well-Known Member
    2006 Double Cab
    Dog hair, lost happy meal parts from Grandkids....
    Flushed mine and filter at 89K, just north of 214k now,
    guess I will do it again this summer...........
    Dang thing runs like a top, paint is peeling and gone, but don't care too much about it.
  12. Mar 28, 2023 at 7:48 AM
    4wdExplorer
    4wdExplorer Well-Known Member
    Orange County, CA
    I flush mine at 30k miles doing the return line disconnect replacing 14 quarts. I flushed my buddies at 60k miles in his 2018 4runner. Flushing is fine. Dont do a flush if you havent changed the fluid prior to 100k miles though.
  13. Mar 28, 2023 at 7:52 AM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    Stop talking to clown “technicians”
  14. Mar 28, 2023 at 9:03 AM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    Changed at 180K kms, now at 190K. Besides smoother shifting, picked up a couple MPG.
  15. Mar 28, 2023 at 2:13 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Just because it is referred to as a “sealed” transmission doesn’t mean it shouldn’t be serviced. The more it’s changed the better
  16. Mar 28, 2023 at 4:25 PM
    2WD
    2WD Well-Known Member
    Pete
    2013 DCSB TRD Off-Road Pre-Runner Taco
    King 25001-119A, JBA HC and superbumps, EL095 leafs with longer overload leaf removed and 2 degree shim, Bilstein 5160 rears with fox roost shield on passenger side, King 2'' bump stops, B&M 70264 trans cooler, CSF FJ radiator, Leer Trilogy X2T bed cover, Scangauge, 34R AGM battery, weathertech floormats, Gold plug on the differential, fancy engine and diff oils, UNI air injection filter mod, Factory antenna chopped 4'', De-badged, Ram mount on A pillar, Cooper ST Maxx 265/75 R16.
    "Sealed" but there is a drain plug, fill plug and check plug. "Lifetime" but that shit is brown before 60k. Yeah the trans will take some time to die without maintenance because it's a good transmission but that doesn't mean no maintenance is the best strategy. I change the fluid and also brush my teeth.
  17. Apr 7, 2023 at 10:25 PM
    1stTimeTaco1
    1stTimeTaco1 New Member
    2021 Tacoma
    Long time watcher, first time posting! I have a 2021 tacoma. I want to do a transmission fluid change, but my obd2 port doesn't have a pin in port 13 to do the jumper. What now? Is this something new or a factory screw up? Besides buying a data scanner what other options do I have?
  18. Apr 7, 2023 at 11:43 PM
    Littlemule1
    Littlemule1 Well-Known Member
    2015 SuperWhite Tacoma DCSB TRD Sport
    This is crazy. Trans fluid isn’t magic it gets nasty too.
    I dropped pan , and flushed 8 new quarts and added a new transmission cooler today 3rd flush in 77,000.
    I just hope I didn’t put to big of a cooler on , took a long time to get to 110 deg to check fluid.upload_2023-4-8_1-42-44.jpgupload_2023-4-8_1-43-16.jpgupload_2023-4-8_1-43-44.jpg
  19. Apr 8, 2023 at 12:17 AM
    Ricardo13x
    Upland, CA.
    My man :fistbump:
    2WD, HondaGM and defdonny[OP] like this.
  20. Apr 8, 2023 at 12:21 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Def change that fluid.. cha fed mine around 60-70 black as night
