Transmission fluid
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jerry07$, Oct 2, 2024.
  1. Oct 2, 2024 at 8:01 PM
    Jerry07$
    Jerry07$ [OP] Active Member
    I have 2019 Tacoma sr5 with 76,000 miles. Transmission fluid has never been changed. Is it a good idea to change it now?
  2. Oct 2, 2024 at 8:07 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yes. Now would be a great time to change it.
  3. Oct 2, 2024 at 8:13 PM
    999 Well-Known Member
    Texas
    Yes
  4. Oct 2, 2024 at 8:17 PM
    Jerry07$
    Which type of trans fluid is best?
  5. Oct 2, 2024 at 8:25 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Yes, change it. There is a lot of discussion on just what to use. Toyota WS ATF is the standard. There are others as is mentioned in many threads. The "Change" you speak of is a dilution of the ATF as you only can drain a fraction of the fluid. Somebody else will have to direct you to those threads.
  6. Oct 2, 2024 at 8:36 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  7. Oct 2, 2024 at 9:08 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Yes, change it, or have it changed. If you will do drain/refill, stick with oem ATF, or WS specific ATF like Idemitsu TLS-LV, which I put in my sister’s 2015 Lexus. If you do a flush, you have the option to change to a WS compatible fluid. Valvoline Multi Vehicle (formerly MaxLife) ATF is the popular option. Mobile Multi Vehicle is another good one.
    My opinion is to do a flush with Valvoline, Mobile, or Idemitsu, then a drain/refill with the same every 30-40K thereafter.
    Tacorific and TnShooter like this.
  8. Oct 2, 2024 at 9:12 PM
    MGMDesertTaco
  9. Oct 3, 2024 at 5:53 AM
    FRE1809
    FRE1809 Well-Known Member
    Long Island,N.Y. ; USN ( Ret.)
    Yes change it if that was my truck I would drain the transmission pan only. I use Amsoil transmission fluid which is WS compatible. I would look at your frame for rust and start a frame maintenance program while your down there. There is a check fluid level sequence which must be followed. USN adage ( 7P) Proper Prior Planning Prevents Piss Poor Performance.
  10. Oct 3, 2024 at 12:58 PM
    Jerry07$
    Thanks!
