Transmission Flush OK?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thumper06, Feb 17, 2010.
  1. Feb 17, 2010 at 7:25 AM
    Thumper06
    Thumper06 [OP] Member
    David
    Arizona
    06 Double Cab 4x4 TRD
    Rear Locker Differential, 3" Revtek Lift Kit, K&N Filter
    Hi, I'm new to both Tacoma's and TW. Just bought an 06 Double Cab 4x4, automatic with towing pkg and 38K miles. On my previous Dodge & Chevy trucks, I have had the automatic transmissions flushed about every 30K miles. I know that's more often than probably necessary but I figure for $100, it's a fairly inexpensive way to extend the life of the tranny.
    Is there any reason this cannot be done with the Tacoma? I don't want to do something stupid out of ignorance with my new truck. I usually have a local Midas Shop do the work, they seem trustworthy.
    Thanks,
    David aka Thumper06:cool:
  2. Feb 17, 2010 at 7:35 AM
    ofrd4fun
    ofrd4fun Well-Known Member
    Vancouver BC
    05 DC 4x4
    FJ Cruiser wheels, air bags, 5100's @1.75, TC UCA's, bi-xenon HID's
    Welcome to TW.
    I only take mine to the dealer as painful as that can be at times!!! There is a special fluid required and a specific way to check the fluid level after it's filled. There is info in this site about doing it yourself. It may convince you where to take it.
    Cheers
  3. Feb 17, 2010 at 7:46 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    To add to ofrd4fun's post, your tranny is "sealed" and has no dipstick. I would not go to anyone but the dealer for this as not following the procedure can cause some issues.
    Here is the link to the procedure.
    Also, the service interval was 100k miles, but Toyota has recently reduced it to 60k for the transmission.
  4. Feb 17, 2010 at 7:47 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    If you look in your owners manual...it should say that the fluid change and/or flush is not required until 100,000 miles (Automatic transmission)
    So why spend the money to do it more than what the manual recommends?
  5. Feb 17, 2010 at 10:40 AM
    Thumper06
    David
    Arizona
    Thanks for the replies & the link. I'm not looking for creative ways to spend money :) but I do know that the biggest enemy of automatic transmissions (other than heat) is sludge build-up in the valve body. It's a slow process that can be largely eliminated by keeping the fluid clean. The only reason I like the flush or purge method is that it gets all of the fluid, including what's in the torgue converter. Again, thanks for the advice.
