Transmission flush
Discussion in 'Technical Chat' started by Hektor, Dec 19, 2012.
  1. Dec 19, 2012 at 3:31 AM
    Hektor
    Hektor [OP] Well-Known Member
    Texas
    04 Tacoma 4x4 TRD DC v6
    Would the dealer be the best place to take my 2003 v6 taco to get a transmission flush??? I wanted to change to synthetic fluid, but I most recommend the toyota fluid for the transmission. My truck has 69k as far as I know the las flush was performed at 40k. Thanks in advance.
  2. Dec 19, 2012 at 3:48 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2015 DC 4x4 base model
    Husky liners, Toyo Open country AT2
    If it was flushed at 40 i would just do drain and fill with type 4. 4 1/2 quarts and be like new.
  3. Dec 19, 2012 at 4:00 AM
    Hektor
    Texas
    The problem is that PO didnt do the flush at the dealer so I dnt know what fluid they used. If I drain and fill with toyota type 4 it should be ok then????
  4. Dec 19, 2012 at 4:06 AM
    TACO TX
    Kelly
    Denison ,Texas
    People mix type 4 and synthetics all the time, i personally wouldnt but they say its ok.
  5. Dec 19, 2012 at 4:06 AM
    zacksblacktaco
    zacksblacktaco Well-Known Member
    west virginia
    06 trd sport access
    AEM CAI Throttle body spacer Borla cat back exhaust Doug Thorley long tubes RCD 4.5 anzo halo projectors with 4300k hids 12000k hid fogs T-rex stainless mesh mesh grille kit in pro car wear LED taillights & 3rd brake LED reverse lights LED license plate lights LED dome & map lights all Kicker speakers with 15 inch L7 subwoofer Jensen 7inch flipout headunit Trd sport seatcovers Re-badged red Tacoma
    AMSOIL or REDLINE ATF or MTF
  6. Dec 19, 2012 at 4:14 AM
    Hektor
    Texas
    For sure she didnt used synthetic that I know for a fact. Now if I put the type 4 it should be ok since it doesnt have synthetic?
  7. Dec 19, 2012 at 4:15 AM
    Hektor
    Texas
    I was thinkin Amsoil, thats why I wanted to do the flush buy dealer eont do it unless they refill with toyota type 4
  8. Dec 20, 2012 at 4:42 AM
    zacksblacktaco
    west virginia
    06 trd sport access
    tell them when your tranny fails you will be more than happy to send them a bill...
    dont let them push you around your the one paying for services
