Transmission Flushing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dmac11, Dec 9, 2009.
  1. Dec 9, 2009 at 12:21 PM
    dmac11
    dmac11 [OP] Well-Known Member
    CT
    '06 2x4 AC
    Upgraded Head Unit w/Aux jack : De-Badged : Black Emblem : x-runner Rims : Seat Covers : Optima Battery : AC Inverter (aftermarket) : Full time 12v : Weather Tech Front Mats : Scanguage
    What is the recommended Change interval on an Automatic transmission in a 2gen (06) tacoma.
    I have a 2wd w/86k driven on it. I am not the original owner and ASSUME that its never been changed.
    I checked the ATF recently and it looks fine, but want to know whats recommended. The manual says nothing of the sort in terms of transmission. And the dealer said he might check it if the cars around 65k and may or may not recommend changing (little did he know i have surpassed this milestone). But failed to comment on what Toyota Actually recommends on 2 generation tacomas.
    Thanks
  2. Dec 9, 2009 at 12:30 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    How did you check it?
    They are not shceduled for maintenance until 100k miles. They designed to be sealed units.
  3. Dec 9, 2009 at 12:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Normal use, 100k miles
  4. Dec 9, 2009 at 12:33 PM
    dmac11
    CT
    '06 2x4 AC
    I checked it with the Transmission dip stick.
    What do you mean by "sealed unit" ???
  5. Dec 9, 2009 at 12:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :confused: Are you a 5 lugger?
  6. Dec 9, 2009 at 12:37 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  7. Dec 9, 2009 at 12:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    if the fluid is a nice red, then you should be fine. With 86k miles, it cant hurt to change it though.
  8. Dec 9, 2009 at 12:44 PM
    dmac11
    CT
    '06 2x4 AC
    Yeah 5lug, Thought all 2wd Tacomas were 5lug sorry.
    Does that make a diff, in the recommended change intravel? IE not 100k
  9. Dec 9, 2009 at 12:45 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Pre-runners (2wd with 4wd suspension) are 6 lugs. That's ok. I thought all second gen tranny's were sealed. Apparently not. :eek:
  10. Dec 9, 2009 at 3:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah...Check the fluid and see what it looks like..If there is any "Brown" tint to it, change it.
  11. Dec 9, 2009 at 4:23 PM
    Front sight
    Front sight Well-Known Member
    SW Florida
    06 Prerunner TRD Sport
    Full OME 3"lift, LR UCA's,Destination 285/70/17's, 1.25 spidertrax, K&N drop in, 2nd filter removed, Weathertech liners, Toyota bed mat, reverse lights,Wet Oklee's, bedlights and other small stuff.
    As was said, check the color and also smell it. If it smells burnt, change it.
