Transmission Frozen?...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jorchu98, Oct 19, 2021.
  1. Oct 19, 2021 at 4:10 AM
    Jorchu98
    Jorchu98 [OP] Member
    Jorge
    California
    2019 Tacoma TRD 4x4OR
    Last weekend I went Hunting and take my 2019 Tacoma TRD 4X4OR. In the morning I turned on my truck and let it warm for around 10-15 min. Went put it to Reverse it didn't move at all and then tried putting it to Drive and nothing... I thought that the E-Brake got stuck or something but no, cause I released the E-brake all the way down 2 times. Then my idea was to put the truck on 4high and it didn't worked. Next I tried to put it on Neutral and 4low and the truck moved but the transmission sounded like if it was stuck or something like a big "clank" sound. After all this truck drove normal like before, never had an issue like this before. Temperature was at 8F outside. Also no signs of leaks from the transmission of differential.
    tacotoe likes this.
  2. Oct 19, 2021 at 4:14 AM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    Have you changed the transmission fluid at all? There's been a couple members on here who received their trucks new with low transmission fluid, but its very unlikely since you didn't have any issues prior.
    Jorchu98[OP] and tacotoe like this.
  3. Oct 19, 2021 at 4:14 AM
    Paddy1337
    Paddy1337 Well-Known Member
    Carroll, MD
    '21 DCSB TRD-OR, '20 Sequoia TRD-Pro
    Might have been the ebrake locked up
  4. Oct 19, 2021 at 4:14 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    The rear brakes had surface rust keeping the e-brake engaged. Common problem. Nothing to worry about
  5. Oct 19, 2021 at 4:18 AM
    Jorchu98
    Jorge
    California
    The truck has 35k miles I never though on changing the oil at this time soon. Probably low transmission fluid??
  6. Oct 19, 2021 at 4:58 AM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    It definitely was the back brakes rusted fast like they said . Mine did it one time in the garage and when it broke lose a big bang . I had to put it in 4 high and give it a good bit gas to get it .
  7. Oct 19, 2021 at 5:03 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Agreed, most likely parking brake. Just because the lever is down, doesn't mean the actual brake components released.
    8 degrees in October, shit man, that's too cold!
  8. Oct 19, 2021 at 5:14 AM
    Clearwater Bill
    Billy
    Largo Florida
    Rear brakes frozen via the ebrake.
    As in cold frozen, not broken frozen.
    Piles of threads on the topic
    Stocklocker, Junkhead and AODRN like this.
  9. Oct 19, 2021 at 5:16 AM
    djgynee
    djgynee Well-Known Member
    Southern California
    2018 Magnetic Grey Metallic Tacoma DCLB TRD Sport
    Rust,frozen temps, loud bang.. everything fine afterwards? I’d go with frozen ebrake. Rare but not uncommon. If It drove normally after that don’t give it a 2nd thought. NOW if it does it again. Maybe letting it warm up for so long the condensation from the exhaust at the rear end added to the freezing at the rear wheel? Maybe start it up. Run a few seconds an move forward/backward a few feet then warm up so you don’t have over night frost on pads then added with fresh frozen exhaust droplets
    Jorchu98[OP] likes this.
  10. Oct 19, 2021 at 5:17 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I've seen brakes freeze in cold weather. Especially after water crossings.
  11. Oct 19, 2021 at 5:18 AM
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    That's a nice Summer cold day here in Canada lol
  12. Oct 19, 2021 at 5:18 AM
    djgynee
    Southern California
    I also see you only have 2 messages so I assume your new here? Welcome. This place has got the answers for everything
    shakerhood and Jorchu98[OP] like this.
  13. Oct 19, 2021 at 5:19 AM
    Clearwater Bill
    Billy
    Largo Florida
    Too complex.
    Just don't use the ebrake.
    If you need extra security because of how you are parked, use a chock.
    44-16 Taco and remote like this.
  14. Oct 19, 2021 at 11:00 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Next time don't force it out. Find your e-brake cable and just shake the crap out of it.
    I ran it in 4low one time when it was stuck and it broke my backing plate and literally twisted my drum shoes. Toyota wanted 2500 for it (basically just replace anything related to that area). I had to pull the axle and had a shop press out and replace the backing plate. I was able to DIY the rest with a friend for ~250.
    Jorchu98[QUOTED][OP] likes this.
  15. Oct 19, 2021 at 6:07 PM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    Happened to me as well after a wash when it only had a couple thousand miles. Tried in reverse; no dice. Finally got it unstuck by rocking it back/forth by the tailgate. You definitely hear when it releases and it took quite a few tries.
    So after a wash or heavy rain, I don't set the ebrake and has not happened since.
    Jorchu98[OP] and Stocklocker like this.
  16. Oct 19, 2021 at 6:19 PM
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    People actually use the parking brake for automatics? Who knew?
    Chew[QUOTED] and 44-16 Taco like this.
  17. Oct 19, 2021 at 6:26 PM
    Heyyo_Friday
    Heyyo_Friday Circle driving enthusiast
    Derek
    Dfw, texas
    2020 tundra 1794
    Rays valve stem caps
    Id bet the e brake stuck. When I wash my car after events and park it in the garage. The first time I move my car this will happen. Just a little bit of extra throttle when I let the clutch out
  18. Oct 19, 2021 at 8:12 PM
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    I rarely set my E-Brake (or Parking Brake if you prefer) if I'm on level ground. I generally park my Taco in a level spot at my house where it'll sometimes sit for a couple of weeks at a time; I make a point not to set the brake when it's parked for long-periods of time for just this reason.
  19. Oct 20, 2021 at 9:43 AM
    513Mugsy
    513Mugsy Well-Known Member
    Cincy
    2020 VOODOO AC OR MT sold now
    Had this happen to me after I washed out some snow from inside all four of the wheels. The rear passenger side drum froze up after driving the 8 miles from the carwash to my parents house. It was around 25F outside. Truck was parked for around an hour and half. Used a wheel dolly, and drove using the open differential to drive the driver's side, into the garage. Took off the wheel and heated up the drum. Everything worked after we took off the drum and dried everything out. That was on my 2016 sport I had. Never used the parking brake again on that truck, and never on my 2021.
  20. Jan 2, 2022 at 10:49 AM
    O_Nevermind
    O_Nevermind Well-Known Member
    2k16 TRD OR DCLB Barcelona Red
    Rain Guards and Bug Deflector.
    Stuck e brake happened to me when I let the truck sit for 24 hours in 22 degree weather. It sat until it was at least 36 degrees outside, and i felt the e brake break free when I released the lever. I also inspected the line to the drums and it seems like the drain holes for the bed of the truck are right above the e brake line. I'm questioning if any water could make it's way down and inside the line to freeze it? I'm gonna 3D print a cover for it for the time being.
