Transmission Gauge
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ortacoma10, May 21, 2024.
  1. May 21, 2024 at 8:15 AM
    Ortacoma10
    Ortacoma10 [OP] Well-Known Member
    2010 Tacoma Trd Off-road 4x4
    Looking into getting a transmission temp gauge for my 2010 TRD OR 4x4.
    What are normal temps with everyday driving it should be within?
    also, drop some links below if y’all can for which one you’d recommend. TIA!
  2. May 21, 2024 at 9:13 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Can't speak for Tacoma as mine is a manual but majority of vehicles I've seen with a factory trans temp gauge run in the 180-210F range (right around what engine coolant temp runs), you never want to exceed about 240-250F for any period of time as the fluid starts breaking down very quickly at high temperature.
    In general the cooler you can keep it the better but it's kind of like an engine in that you don't want to run it at too low of a temperature either.
    Most people go with a scangauge or ultragauge, easy to install and you can monitor pretty much any parameters available via the OBDII port including but not limited to transmission temp, coolant temp, battery voltage, etc plus it doubles as a basic code reader.
  3. May 21, 2024 at 9:15 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Ideally under 200’
    Temp gauge, Just buy a digital one that uses the OBD port.
    Ortacoma10[OP] likes this.
  4. May 21, 2024 at 8:43 PM
    Bman562
    Bman562 Well-Known Member
    SoCal, CA
    2005 Radiant Red Tacoma Sport DCSB
    '12+ Facelift, TRD Baja Bilsteins, SCS Ray10's, K02's...
    I believe the ideal temp during normal driving conditions is under 200.. could be wrong.
    Many guys here run a scan gauge (model 2 or 3) to monitor several things, including trans temp.
    https://www.scangauge.com/
  5. May 22, 2024 at 4:15 AM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    I track mine via the OBD Fusion app and a Bluetooth OBD reader, and it’s worked out great. I think the other alternative is the Torque app and a reader. I’ve used the OBD Fusion’s function to save the trans temp in a directory as an excel file. You can also see the live pan temp via the app.
