Transmission Gear / Diff Ratio / Tire Size Speed Calculator
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mark1285, Feb 24, 2017.
  1. Feb 24, 2017 at 8:36 AM
    mark1285
    mark1285 [OP] Well-Known Member
    Mark
    2017 Tacoma TRD Off-Road
    I created the attached excel file for different gearing / tire size and transmission gear speed calculations because I was unhappy with the various calculators online.
    I'm re-gearing my Tacoma to 4.88 and putting on 33" tires and wanted to know the changes vs stock. This told me that for various gears RPM ranges.
    I thought this may be useful to other people on here as well, who wanted to quickly see what changes in tire size and gear ratio do you your actual speed.
    Basically, enter all fields that are yellow. First block at the top is for up to 4 different tire sizes. Middle blocks let you set trans Gears and diff ratios (set for 3rd gen already)The larger block at the bottom lets you set an RPM, trans gear, diff ratio (both via selecting from the middle blocks), and Tire Number (which is just tire size from the top chart). Outputs are Driveshaft RPM Axle RPM, and Speed in MPH.
    Please let me know if anyone finds a mistake. Feel free to mod away if it needs additional features!
    Enjoy!
    John90XJ and Curtis_H like this.
  2. Feb 24, 2017 at 8:43 AM
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    You will want 4.56s for 33s and 4.88s for 35s!
    raco.the.taco likes this.
  3. Feb 24, 2017 at 8:44 AM
    mark1285
    Mark
    4.56's not available for third gen, so 4.88's it is.
    Curtis_H likes this.
